![]() | Home > Maintenance & Modifications > LOF Brakes Powerspec Upgrade - User feedback please |
mark1200 Member Since: 09 Oct 2011 Location: peterborough Posts: 76 ![]() ![]() ![]() |
Just to echo what Landy Andy has said i chose to get the Lof brake kit as it was a lot cheaper than genuine landrover parts ( the green oval tax )
In my case it was the Lof pads that were not working as they should have and a change to Ebc green stuff pads have a huge and dramatic improvment. My brakes are as good as standard but maybe its in my head but i wonder if there just a little better lol |
Fossil Member Since: 23 Aug 2015 Location: Bolton Posts: 17 ![]() ![]() ![]() |
Maybe the same issue but the brakes on mine (300tdi 90) were fine on gentle stops but an emergency stop needed a massive push and they lacked 'bite'. The power assistance seemed to be there but maxed out on a hard stop. The calipers had been rebuilt with new seals and had stainless pistons, LOF performance pads. You could feel the pedal was really hard, so not a hydraulic issue. The vacuum pump was new and measured fine (.65 bar). So I decided the servo was faulty, and because of our age we need that power assistance! When I took it off I found that there was slight rusting of the servo within the cavity at the back of the master cylinder, and it had disturbed the O ring that seals the two together. It was not visible from the exterior. So I guess there was a small leak (by then I had bought the LOF upgrade which has made a massive difference).
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2661 ![]() ![]() ![]() |
Interesting reading this thread, as lately I'm feeling that my Puma could do with a braking upgrade: I have the BAS remap and I drive like a hooligan
![]() Would just replacing the OEM pads with the EBC Green stuff provide any added braking performance? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3350 ![]() ![]() ![]() |
Standard brakes work just fine on even the most highly tuned Puma, we are only talking 190bhp after all. For longevity you could swap for stainless pistons but that won’t improve performance. Braided hoses and upgraded pads are helpful especially if you tow a lot and you could always use motorsport brake fluid dot 5.1.
The truth is Defender brakes are actually pretty decent when set up correctly. WARNING. This post may contain sarcasm. Last edited by Zed on 13th Dec 2024 5:04pm. Edited 2 times in total |
My brake system was 20 years old and had 90,000 miles on them so i got really good use out of them.
I would have changed them and used genuine land rover kit but i chose the Lof kit as it was less cost and lets be honest a brake disc is just a brake disc unless your paying mega money and going carbon fiber ect. The Lof pads just did not work for me so that's why i changed to Ebc green stuff and now my brakes are as good as how land rover intended. I realise that the Ebc green stuff are a softer compound and will not last as long but in my case that is not really an issue. |
