Home > Puma (Tdci) > Axle level and drain plug square size?
Johan_B
Sweden 2008 Defender 110 Puma 2.4 CSW Tonga Green
I was about to change the oil in the axles yesterday and to my surprise I wasn't able to use a 1/2" drive in the plugs. I could have sworn that I used that on previous Defenders. Is it just a matter of removing all the rust (which I did try to do) or is it another size on these? If so, what size would that be? 3/8" was too small.
Do I run any particular risk if it turns out that these are stubborn? Or is it just to apply whatever torque required?
Post #1054443 11th Dec 2024 3:33pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I’m 99 percent sure they take a 1/2 inch extension bar. They’re a tapered thread I think, so I can’t see any harm in putting serious effort into undoing them, but I’m sure if there’s any particular reason not to do this someone will read this and correct me! I’m guessing that trying them when it’s all warm will help. 1983 110 automatic OM606
Post #1054446 11th Dec 2024 4:58pm
Ianh
They are a 1/2 inch square drive, so I expect they need a good clean. A little heat around the plug won’t hurt either, nor will a sharp tap with club hammer on the 1/2 inch extension bar.
Edit. By which I mean a tap with a hammer to rotate the T bar , not to punch the plug inwards Very Happy
Just do the fill plug first so you know you can refill once drained. And think about fitting magnetic drain and fill plugs if not already fitted.
Post #1054453 11th Dec 2024 6:09pm
I fitted mag plugs to mine just this year, I find usually the old plugs will come out with a standard square drive ratchet, if they are really tough, you can use a breaker bar gently just for a little help to start them off, usually you don’t need to and only used for removing and definitely not refitting.
They are tapered as mentioned, there is a torque setting for them, and the LT230, which is useful to avoid over tightening especially important with the Transfer box not to over tighten because they alloy casing. TheThunder Rolls🇬🇧🇺🇸
Post #1054459 11th Dec 2024 7:50pm
Johan_B
Thanks to all! I'll give it another try during the weekend. It is easier to proceed with confidence when backed up with this knowledge. Smile
We have a 5000 km Christmas trip ahead of us so I thought it would be nice to have this done before, but also not to immobilize the Landy due to me messing up.
Post #1054477 12th Dec 2024 7:34am
revd
this tool has tapered ends which should ease fitting into the drain-plug and costs less than a tenner
https://www.drapertools.com/product/07179/...mm-8-size/
Post #1054488 12th Dec 2024 12:37pm
Alternatively buy a short, low-cost 1/2" drive impact extension and file or grind a taper onto the male square end.
Post #1054491 12th Dec 2024 1:06pm
Johan_B
Success! At least with the axles. A good cleaning of the plugs and 1/2" square fitted.
TC on the other hand, I filled with 2 l and then it started to pour out of the filler hole. I know the filler is not a level hole. Any clues as to what is going on?
I can not guarantee that the car is level, if anything it is nose down but not by much.
Post #1054680 14th Dec 2024 6:36pm
Ianh
The TC filler is the level plug, I believe most only get circa 2L or a little bit more on a Puma TC refill. Although I believe 2.4l is quoted as capacity.
Post #1054687 14th Dec 2024 8:04pm
Johan_B
Ok. I thought that was changed with the introduction of Puma and that the service fill was specified to 2,2 or 2,4 l.
Post #1054709 15th Dec 2024 7:01am
On the Puma it is the MT82 for which the filler plug is no longer a level plug, the LT230 remains as before.
Post #1054713 15th Dec 2024 8:58am
Johan_B
Then all is good. The MT82 got 2,2l this morning as well.
Thanks for all the support!
Post #1054735 15th Dec 2024 1:32pm
Evil Elsie
United Kingdom 2002 Defender 110 Td5 HT Alpine White
Hey Johan,
I've got to ask - 5000km trip..?? Going to visit Santa..?? 😀
Cheers, Dave 2002 Land Rover 110 Td5 Utility
1990 Suzuki GSXR 1100L
1980 Yamaha RD 350LC
1976 Yamaha RD 400C
Post #1054737 15th Dec 2024 3:40pm
Ianh
2.2Litres for the 2.4 and 2.4Litres for the 2.2 is specified by LR. Given its the same MT82 at the same angle who is to know why the different quantities. Having a 2.2 I measured the drained amount on the first ever MT82 oil change and it was 2.4Litres, so that’s what I put back in.
Evil Elsie wrote:
Hey Johan,
Cheers, Dave
Sssssshhhhhh.....He is Santa and that’s just the first of many trips.
Post #1054739 15th Dec 2024 4:49pm
Johan_B
It’s a game with numbers isn’t? 2,2 for the 2,4 and vice versa. I drained a bit more than 2,4 but only put back 2,2-2,3. Probably the first ever for this box too. But I’ve read here of everything from empty boxes from factory to 3 l in the first drain so it seems LR wasn’t so precise in their filling.
We’re going south to central Serbia. My kids want to dress the Landy up as a reindeer, not sure how they will do that, so you’re not so off. I doubt we can reach the speed required for santas logistic challenge.
Post #1054740 15th Dec 2024 5:12pm
