Home > General & Technical (L663) > Does anyone know how to activate air quality sensor with gap |
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 95 |
It can't be activated, as the air quality sensor is a hardware piece that requires both the three-zone climate control and the Cabin Air Purification Plus package. All cars with three-zone climate come with the air quality sensor and Cabin Air Purification Plus. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red) 𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone 𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone |
10th Dec 2024 2:37pm |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 51 |
The programming side using GAP IID tool is easy. But you need some hardware. The first is a pollution sensor instructions below. You will also need the Ionizer.
https://www.lrdefender.org/pollution_sensor-715.html AIR IONIZER NOTE: RHD vehicle is shown, LHD vehicle is similar. Control Components The air ionizer technology helps the well being of both driver and passengers. The air ionizer improves the air quality within the passenger compartment and can help reduce allergens, viruses, bacteria and odours. The air ionizer uses nano-sized charged water particles which decompose harmful substances to cleanse the air. The air ionizer can be switched ON or OFF through the climate settings on the FCDIM. The air ionizer is only connected to the left center face vent in the instrument panel. The air ionizer is connected to a power supply and a ground connection. The air ionizer operates when an electrical signal is received from the HVAC control module. |
10th Dec 2024 10:39pm |
MarcJennings777 Member Since: 14 Nov 2024 Location: Youngstown Ohio Posts: 2 |
Thank you. I was hoping it would be a simple activation. It looks like I won't be doing all that just to have it. I appreciate the info though!
11th Dec 2024 2:09am |
Mukafuka Member Since: 28 Dec 2022 Location: New york Posts: 6 |
My vehicle is equipped with the the three zone system and the ionizer. I change the CCF for PM2.5 with the gap but can't view the particulate matter levels. Do you know of another setting that controls this? |
31st Dec 2024 2:07am |
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 91 |
How hard would it be to fit them. I thought the clearsight retrofit was beyond me but it was a piece of cake! |
22nd Jan 2025 2:01pm |
