![]() | Home > Puma (Tdci) > Stainless Bolts etc |
scottish110 Member Since: 10 Nov 2011 Location: Inverurie Posts: 363 ![]() ![]() ![]() |
Iv just bought stainless steel bolts and screws from Paddocs to cover pretty much the whole truck, but i was wondering if i should put any sort of anti corrosion stuff on them before putting them on ?
Any suggestions ? Thanks |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
got a link? and yes, copperslip at least. i do believe there are some special pastes for cross metalic corrosion |
Duralac
Que K9F ![]() The better companies who supply stainless bolts etc for 4x4 supply a sachet/small tube of anti corrosion paste from Wurth Brendan PS Information available HERE Last edited by leeds on 7th Dec 2011 10:00am. Edited 1 time in total |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Duralac Chromate Paste
Glasgow stockist: http://www.duncanyacht.co.uk/search.asp But any yacht chandlers will stock it. |
http://www.paddockspares.com/parts-and-acc...xings.html |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
On steel built cars you can use copperslip, but dont do that on our aluminium shells - building batteries does not solve problems! Go for TefGel, Weicon Anti Seize or anything related instead. BTW what does MOT tell you about stainless bolts? our German TÜV might be very unhappy /w stainless bolts on chassis carrying parts. Never forget: cars have owner, Landrover have field service personnel.
same here, you shouldn't use SS fastners on any stress or load bearing fastenings 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5025 ![]() ![]() |
Stainless steel DOES rust and is not very strong, it's not necessary to use them. Use proper fasteners and cover with usual suspect potions if worried about rust!
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 ![]() ![]() ![]() |
ah, if only our friends at Land Rover would use proper fasteners in the first place...
Go retro and use sheradized fasteners...many of them were still fair on my Series 1 when I bought it - those were the days ![]() 1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
not strictly true Zag - you can buy different grades of stainless (as you'll know from your boating exploits) and when specifying stainless bolts you can specify ones which are actually stronger than 'ordinary' steel bolts - as always it's worth checking the application and buying accordingly. |
I stand corrected
I'm confused now ! Zegato, are you suggesting that I do not use the stainless bolts fro
Paddocks to replace the rusted ones ??? |
S110 there is a large number of metals referred to as stainless steel. These are resistant to corrosion in different environments.
The two most common stainless bolts are referred to as A2 and A4 A2 is nominally resistant to corrosion in fresh water A4 is nominally resistant to corrosion in salt water and chemicals Common stainless bolts are referred to as A2-70 A2 meaning resistant to rusting in fresh water the 70 refers to strength and is 700 N/mm2 A standard mild steel bolt is marked 8.8. The first 8 refers to a strength of 800 N/mm2 whereas the .8 refers to stress at permanent set being 80% so ).8 x 800 = 640 N/mm2 Real High Tensile bolts are rated 12.9 12 refers to strength of 12 N/mm2 whereas the .9 refers to stress at permanent set being 90% or 1,080 N/mm2 That is the general reason why stainless bolts in high stress situations are not recommended. HTH Brendan |
Brendan knows the theory I only know that many advise not to use SS bolts on resto's/rebuilds due to strength/cost and they do rust anyway. Sheradised stuff is costly so most use the standard zinc coated fasteners, I bought ALL the correct size UNF fasteners for my rebuild for £110 ![]() ![]() |
