![]() | Home > Td5 > LynxEvo + battery charger |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1644 ![]() ![]() |
you can leave battery connected with most modern chargers no problem
dont try to start the car unless the charger has a a boost/ start setting as you can kill it with the voltage spike. |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 281 ![]() ![]() |
So ... connecting battery charger made no difference.
Now wondering if theres an issue with the connector between odbc and. EMS. lrworkshop is your friend, apart from some earth wires theres only 1 wire going to the ems from the plug. Guess id better check the continuity Backup plan is that local LR people at LR Refurb ( North Newbald) will flash the EMS with the new injector codes for me if i take it there. Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
and of course you cant just take the ecu to them to do as it relies on some interaction with the AS10 module.
Next question - been told the td5 will run with injectors without correct codes but will be "a bit rough" its 16 miles to mot station ( car currently sorned) and then. 40 miles from there to landy garage just wondering about driving that distance with incorrect injector codes ... A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 642 ![]() ![]() ![]() |
With good charged battery no need for charger when usig diag. Especially on Def TD5, it takes some power from battery, but much smaller than other modern cars, full of electronics.
TD5 engine runs with any TD5 engine ecu, it need only synchronized immo (or removed from engine ECU) and correct type of gas pedal (with wrong type, it will only idle). For single use, like to get car from mountain road down to garrage, no problem. Just drive it gently. With right map it is better, with correct injector codes engine runs smoother. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
