![]() | Home > Td5 > Axle Rebuild Help (ABS & Shock Mounts) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Those are the rear damper lower bush cups, they are needed if you have pin to eye rear dampers.
You can take them off and use pin to pin dampers with a different top mount fitted, I would take the cups off leaking just the axle hole in the bracket. So remove just the remains of the cups flush to the bracket. The hole in the bracket remains, and that’s where you’d install the pin to pin damper, and appropriate pin to pin bushes. There are different lower bushes for the eye to pin dampers with the cups, to pin to pin with it the cups. If you look up pin to pin rear damper conversion, on YouTube there is videos on techniques to take those cups off, a cold chisel is one ideal tool. Just avoid damaging the brackets or hole in it. This sounds more complex than it is, if you want to keep the cups, you’ll need to get new ones and they are spot welded, I wouldn’t bother. That’s just me. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1443 ![]() ![]() ![]() |
Hi, Regarding the bush cups.
The old ones can be chiselled or ground off and the area cleaned up with a grinder or file. When refitting the shocks, use lipped washers or bushes to prevent rubbing on the eye of the bracket. Explained here, Part number for lipped washer, RYF500200 or NRC4365 If you've got conical bushes at the lower shock mount the cone and the dish of the washer should face away from the mount, for articulation. Bottom of this pic, ![]() Click image to enlarge |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
As said. The bush caps serve no real purpose as most aftermarket dampers come with lipped washer. So no loss there.
The ABS sensors just need a gentle bit of love to get them moving and the they will just pop out ![]() ![]() |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Remove the axle cups. They serve no purpose if the correct washers are used. If anything they are detrimental and cause shocks to snap.
Sensors gently tap them out with rubber mallet. Try and clear as much debris as you can. Very gentle taps. Instagram @defender_ventures Empire Tuning - Agent |
AdamFeneley Member Since: 27 Dec 2023 Location: Bedfordshire Posts: 2 ![]() ![]() |
Thank you all for the feedback, I will remove the cups!
I have removed the ABS sensors, but i will need to replace. They really were stock in there. The housing on the hub they fit into is corroded on this inside of the hub, is this possible to replace (not the brass cage that fits inside the housing)? |
Yes, must replace the brass cage. They are available.
If you get new sensors use G rated ones only, cost around £180. I wouldn't replace them unless yours are faulty or damaged. Instagram @defender_ventures Empire Tuning - Agent |
