Home > Td5 > Axle Rebuild Help (ABS & Shock Mounts)
AdamFeneley
Hi All,
So I have had my 05 110 TD5 XS for nearly a year now. I have done a few bits, but now built up the courage to start some of the bigger jobs! I have removed the rear axle with the intention of a full refurb (only started with the job of replacing the a-frame ball joint!)
I have watched as many youtube videos as i can, but there are a couple of areas that i was hoping to get some help. Current issues:
1 - ABS Sensor removal. My sensors seem to be really seized in, does anyone have any tips for removing these:
2 - The seats/cups (terminology!?) where the socks attach seem to be fixed to the axles. The are knackered, but i was expecting this to be just a hole in the pressed steel rather than for these to remain attached to the axle. Are they just rusted on and I should cut them off or should they remain attached and can you replace them? Sorry if this is a stupid noob question!!
3 - I am going to get the axles shot blasted and will paint them before rebuilding. What are the best primers/paints to use? Am I best to just calling Buzzweld and asking them or is there an accepted best product/(s) to use? For info, I intend to hand paint with a brush as I don't have the gear to spray.
Thanks for any help that you can give me before I start breaking sensors and cutting bits off that I shouldn't be! Laughing
Post #1054063 7th Dec 2024 1:14pm
Those are the rear damper lower bush cups, they are needed if you have pin to eye rear dampers.
You can take them off and use pin to pin dampers with a different top mount fitted, I would take the cups off leaking just the axle hole in the bracket.
So remove just the remains of the cups flush to the bracket.
The hole in the bracket remains, and that’s where you’d install the pin to pin damper, and appropriate pin to pin bushes.
There are different lower bushes for the eye to pin dampers with the cups, to pin to pin with it the cups.
If you look up pin to pin rear damper conversion, on YouTube there is videos on techniques to take those cups off, a cold chisel is one ideal tool.
Just avoid damaging the brackets or hole in it.
This sounds more complex than it is, if you want to keep the cups, you’ll need to get new ones and they are spot welded, I wouldn’t bother. That’s just me. TheThunder Rolls🇬🇧🇺🇸
Post #1054070 7th Dec 2024 1:33pm
DSC-off
Hi, Regarding the bush cups.
The old ones can be chiselled or ground off and the area cleaned up with a grinder or file.
When refitting the shocks, use lipped washers or bushes to prevent rubbing on the eye of the bracket.
Explained here,
Part number for lipped washer, RYF500200 or NRC4365
If you've got conical bushes at the lower shock mount the cone and the dish of the washer should face away from the mount, for articulation. Bottom of this pic,
Post #1054147 8th Dec 2024 12:57pm
landy andy
As said. The bush caps serve no real purpose as most aftermarket dampers come with lipped washer. So no loss there.
The ABS sensors just need a gentle bit of love to get them moving and the they will just pop out Whistle Whistle
Post #1054162 8th Dec 2024 3:10pm
bankz5152
Remove the axle cups. They serve no purpose if the correct washers are used. If anything they are detrimental and cause shocks to snap.
Sensors gently tap them out with rubber mallet. Try and clear as much debris as you can. Very gentle taps. Instagram @defender_ventures
Empire Tuning - Agent
Post #1054170 8th Dec 2024 4:50pm
AdamFeneley
Thank you all for the feedback, I will remove the cups!
I have removed the ABS sensors, but i will need to replace. They really were stock in there. The housing on the hub they fit into is corroded on this inside of the hub, is this possible to replace (not the brass cage that fits inside the housing)?
Post #1054224 9th Dec 2024 8:43am
bankz5152
Yes, must replace the brass cage. They are available.
If you get new sensors use G rated ones only, cost around £180. I wouldn't replace them unless yours are faulty or damaged. Instagram @defender_ventures
Post #1054225 9th Dec 2024 8:45am
