![]() | Home > Technical > Calling Mantec Spare Wheel Carrier Owners. A Question. |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Hello all Mantec spare wheel carrier owners.
Quick question. Once everything is mounted, the swinging arm and the fixing plate on the door, and they are connected, is there a way to release one from the other without fully unbolting or unscrewing the arm? i.e. is there a slide bolt or catch that allows for the carrier to be temporarily released and swung away from the door, without the door opening? If it is possible, can someone please describe how it works? Or provide any photos? Ta. Be useful to know. ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5852 ![]() ![]() |
This sort of thing.
![]() Click image to enlarge The carrier bit would be fitted between washers and before the two nuts in the picture |
Thanks for that. Makes it a bit clearer. Was looking to see if there was a quick release, with wheel on, rather than unbolting like this, and I’m guessing only once the wheel has been removed. It was for quick access to the tailgate, which I will swap to swing away at some point. Monsieur Le Grenadier
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1218 ![]() ![]() ![]() |
Assuming that you reviewing options, I have and have had a few options and this was my conclusion:
-anything hanging off or permanently connected to the door puts a lot of strain on what is quite a weak door especially if you have a habit of slamming it closed -anything not connected to the door and therefor with two stage closing (door then secure the swing carrier) has a risk of you forgetting to secure the wheel. Therefor there needs to be restriction in swing to avoid the wheel potentially swinging open and hitting something or worse someone. Overall I don't think there is an ideal solution. On my DCPU where there is the hatch, not a door, the wheel carrier is not connected but it has a door style latching mechanism which at least makes it quick to secure the wheel as you just close it, this is not too bad a solution I think even if you had a door. Not sure if someone made it or if it was purchased. |
Thanks Texas.
"On my DCPU where there is the hatch, not a door, the wheel carrier is not connected but it has a door style latching mechanism which at least makes it quick to secure the wheel as you just close it, this is not too bad a solution I think even if you had a door. Not sure if someone made it or if it was purchased." Have you got a photo? This is what I'm thinking I need to do/create. Inspiration would be great. Eventually I do want to swap my hatch for a 1/2 swing away door or add hinges to the hatch. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4255 ![]() ![]() ![]() |
I'm pretty sure there was a version of the Mantec for pick-ups that wasn't connected to the door and latched and the left side of the tub. 2007 110 TDCi Station Wagon XS
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge So I cannot find any make, not sure if this was home made. It works well with the pull handle and it latches so it quick and decisive to close |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge This is my series 88 CSW. To avoid drilling holes in the door I got (used) a swing away wheel carrier, but the latch being on the wrong side and a bit jammed, one day it released and swung open. It also made a banging noise against the door as it was not tight. I made the bar to lock it on the existing Antiluce latch. I also added a bolt to stop it from swinging where it not be swinging |
