Home > In Car Electronics > Dodgy Right Headlight, Indicator and Horn. What thoughts? |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5829 |
Evening all.
As per the subject, I’ve got some electrical gremlins I want to sort out. My right headlight (LED with halo daytime running light that comes on when the side lights are switched on), is currently yellow rather than bright white on the halo setting, and then projecting at funny angles on the main (not full beam), almost as if the light isn’t fully working. In addition, when I indicate right whilst on side lights, no problem. When I indicate right on main/full beam, doesn’t work at all. And when I first switch on side/full beam, there’s a flicker on the dash board on the turn signal indicator. And finally, my horn seems very dull sounding. Not a clear toot. In fact dull enough that some people don’t hear it. This all sounds like wiring/power problem to me. I am a complete dunce when it comes to electrical stuff. What should I be looking for? And where? Dodgy wiring? Crossed wiring? Frayed wiring? Some servo or fuse problem? Etc etc Help, as always, appreciated Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
4th Dec 2024 4:09pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5722 |
Sounds like you have an earth fault.
4th Dec 2024 5:00pm |
Thank you all. Seemed to have occurred after the gearbox was removed, so could be the one. Monsieur Le Grenadier
6th Dec 2024 7:22am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20413 |
That’s likely to be one of those two ground points then, by the time the trans goes back in fatigue sets in. And the grounds are often just nipped up or finger tight which causes issues.
Not guaranteed but you never know, it’s a common scenario. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
6th Dec 2024 1:59pm |
