![]() | Home > Puma (Tdci) > Tdci instrument cluster stopped working |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
On a 2.2, look at fuse 4 (ignition) and 29 (permanent power).
Has your clock stopped, do your interior lights work? ![]() ![]() |
CrisEverett1975 Member Since: 26 Aug 2022 Location: High Wycombe Posts: 6 ![]() ![]() ![]() |
Just fiddled with all the fuses again and somehow it works. Very odd, I guess that is defenders!!
Andyslandytd5 Member Since: 06 Nov 2021 Location: Southampton Posts: 38 ![]() ![]() ![]() |
I had this same thing yesterday. No speedo, rev counter etc. but had a trailer light on. Indicators worked as said before too.
I installed a stinger a month back and this died 10 mins later but flashed on and off from time to time. Got home and pulled out the cluster to check connections. It was the same even when I bypassed the stinger wiring loom. Checked the battery connections and put all back together and it started working again. After reading the above I am going to check the fuses too just in case something is loose 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present 2004 TD5 90 XS Station Wagon - 2019-2024 2003 TD5 90 G4 LE - 2009-2010 1990 Ninety 6.2 V8 Station Wagon - 2006-2009 |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2124 ![]() ![]() ![]() |
We had this happen on a trip round Europe a couple of years ago, everything was good, no fuse issues no relay issues, all the switches operated properly, just nothing on the binnacle ...
we were in France at the time and it was a bank holiday, pouring down with rain, looking for a garage that had been recommended, getting lost after a couple of hours driving and round round a town ... then all of a sudden it all came back on and has been fine ever since .. its one of those Puma mystery things !! (its surprising how much you can strip a puma dash down at the side of the road in the middle of a town fault finding with out anyone batting an eyelash ! ) ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
And if you can pretend that you know what you are doing you can impress the locals! 1982 88" 2.25 diesel
