Home > Technical > GNSS antenna
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
GNSS antenna
Question for the more knowledgeable then me gurus. I'm fitting a 5G/Wifi/GNSS antenna the one in the link
https://ie.rs-online.com/web/p/multi-band-antennas/2766675
Is it overkill, yes, is it free, yes
My question for the GNSS to work correctly does it have to have direct sight above it. I was planning on fitting it slightly under the roof tent, would the GNSS work correctly or would i have to install it further to the front of the roof
Post #1053103 27th Nov 2024 1:02pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
GNSS receivers are very sensitive nowadays and happy work with signals that bounce off from all sorts of obstacles. So, there's a good bit of margin.
Of course, a clear view on the sky is always better, especially when driving under e.g. heavy foliage.
Honestly, I would be more worried about the 4G/5G performance when the antenna is somewhat obstructed. Usually the link margin on terrestrial comms is much less compared to GNSS. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #1053106 27th Nov 2024 1:18pm
shanecl
Thanks for the detailed reply Peter,
I'll tell you my plan, I managed to get a sim router from work so my kids will have Wi-Fi in the defender and then i need a GPS antenna for my head unit so i can use apple carplay.
Thinking using this antenna would tick off all my requirements
Post #1053112 27th Nov 2024 2:19pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I'm using GPS on our Discovery 2 during trips, and had antenna on the roof - just behind the windshield edge partly covered by roof tent. It was working, but not good. I've moved it in the hood, nex to some solar panel, and it is perfect.
With TD5 Defender I had placed the GPS antena bellow plastic cover on one of fender top holes. It is hiden and works nice. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1053171 28th Nov 2024 6:55am
shanecl
OOh like that idea of it under the vent on the fender, nice and sutle.
Cool, i'll get working on a bracket Very Happy
Post #1053186 28th Nov 2024 10:26am
MadTom
I have not used any bracket, just the original plastic cover. It has some ribs from lower side, so removed part of the rib, made some holes to the rest and used zip ties to hold the GPS antenna. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1053230 28th Nov 2024 4:13pm
shanecl
Oh sorry, get you now Very Happy
Post #1053323 29th Nov 2024 1:03pm
