Home > Faults & Fixes (L663) > Stop Safely Electrical Fault Detected - D250 Problem |
91dm Member Since: 26 Feb 2024 Location: Ireland Posts: 33 |
Hello,
Looking for a second opinion on this: Click image to enlarge Stop safely Electrical fault detected This appeared last week after a first start up, I had just put the heater on and auto lights on. Switched on and off a few times but didn't change. I checked with a meter and it was showing only 11 volts when running. After a few starts and opening doors it was showing a low voltage message. I'm annoyed because I forgot to plug it the scanner before Land Rover collected it. I was expecting them to say the alternator was at fault but they're saying it needs a new battery. Can a bad battery cause the alternator to not 'trigger' and start charging? Any advice appreciated. Thanks |
25th Nov 2024 9:00pm |
Funny mine didn't show a low voltage until it was running for awhile.
I've done lots of google searching today and read someone had a DC/DC converter and battery issue which resolved it. The Belt Integrated Starter Generator (BISG) issue seems to be on later models and I checked my VIN online which shows no recalls. I find it hard to believe a new battery didn't last 3 years?! |
26th Nov 2024 7:54pm |
nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 98 |
I had this with my P400 the day after I bought it.
That same day a recall was announced for the software update for the “alternator” (no longer called alternator and too early to remember the correct term) Since I had the update done, no issues at all. |
27th Nov 2024 5:40am |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 323 |
SSM76173 refers to this:
1st Dec 2024 10:21pm |
Thanks Fifth Horseman, very useful sounds exactly my issue.
The garage told me last week they thought it was now the DC converter but haven't heard anything since. |
5th Dec 2024 8:49pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20441 |
Are you sure the brake fluid doesn’t need topping up to the maximum mark, if it isn’t it’ll send signals back to the ECU of brake faults.
It does this on a Puma, so might be a thing to look at anyway.. You never know. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
5th Dec 2024 8:55pm |
The latest from the garage is new DC converter to be fitted next week. Will update how it goes.
8th Dec 2024 10:05am |
