Home > In Car Electronics > Help with fitting a new head unit please? [Solved] |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6610 |
Nice work 1988 90 Td5 NAS soft top
2015 D90 XS SW |
24th Jun 2015 9:48pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Glad you got it sorted
Liking the display colour of the new head unit too, should go well with the instrument displays. |
25th Jun 2015 7:24am |
C90 Member Since: 19 Nov 2024 Location: Essex Posts: 17 |
Ten years later nearly, I am having the exact same problem. Pioneer aftermarket head unit but the holding cage doesn't fit within the slot that the factory headunit came out of!!
Tempted to dremel the slot a little bit bigger but was hoping for someone to give me an obvious solution that I hadn't thought of. |
19th Nov 2024 6:59pm |
I was hoping that I had a tab slightly bent out too so just tried again and that isn't the case for me but I can see that on either side there is a metal plate stuck on which I guess holds in the factory one in that reduces the size of the recess by a mm or two each side. This is what's stopping my cage going in! I have no idea how to get them off. Sleep on it and come back with fresh eyes tomorrow.
19th Nov 2024 8:04pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5725 |
A small metal plate each side??
I donโt recall that on the fascia. Got a pic? |
19th Nov 2024 8:18pm |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 163 |
My 2008 has a little metal clip on each side of the radio aperture. You can relatively easily prise them off with a small screwdriver to make the aperture marginally wider, or to allow more significant enlargement work if required. If you don't alter the plastic surround, the same clips can be put back on when you install a head unit which is a more comfortable fit.
I seem to remember that they aren't shown as a separate part, just part of the centre panel, but I may be wrong about that. |
19th Nov 2024 9:18pm |
Thank you for your help so far fellas!
I actually did exactly that this morning, took a little screw driver out and popped the clips off thinking I'd cracked it. Tried again and the poxy thing still doesn't fit. Proper WTF moment, I have fitted a million steroes into cars in the past and they always just slide in (that's Land Rover for you I guess ) I REALLY don't want to cut anything away, thinking about returning the Pioneer that I have and buying a factory Alpine from the 2.2 and hope that fits in perfectly. Here's some pics Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
20th Nov 2024 11:08am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20441 |
I took those off mine too along time ago, itโs hard to notice those are there but will crush the din cage in and make it too tight a fit if they arenโt taken out.
They blend in very well to the dash edges youโd hardly notice they are there until the din cage is difficult to fit in. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
20th Nov 2024 11:34am |
Circa 2009 I fitted a JVC head unit that was marginally too wide, even with the metal clips removed. I just gently and evenly ground down the plastic on either side with a dremel until it fitted. It only took a miniscule amount and could equally have been achieved with sandpaper.
12 years later when I came to fit a new head unit the aperture was bigger than really necessary. It could probably have managed with the bendy fixings on the single DIN cage, but I had acquired a spare centre panel by this time, so just swapped that in (complete with little metal clips!). |
20th Nov 2024 10:04pm |
Yes very true, there is some fine differences there so any plastic material removed, you canโt go back so be very cautious doing that and keeping the clips is worthwhile.
If you need to find them years later that might be a bit more difficult though. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
21st Nov 2024 9:55am |
I just went back to try again one last time before I did the deadly deed and started removing plastic, which I REALLY did not want to do.
Whether it was something to do with a change in temperature, because I was trying again in daylight or if I was just being a K110B (or all three), with a bit of a waggle but surprisingly easier than expected it blooming fitted this time!! So... I am now sorted without tampering with the hole (so to speak). Click image to enlarge |
25th Nov 2024 2:10pm |
25th Nov 2024 6:15pm |
Something very familiar about that "wasted a whole afternoon and then the following morning it all just worked first time" feeling!
25th Nov 2024 8:37pm |
