Home > General & Technical (L663) > Air suspension hiss after sitting |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 431 |
Yes it's normal, I can't explain but mine is doing this for 3.5 years. No Mud flaps for my 90.!
----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
24th Nov 2024 10:29pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3685 |
Is it not the vehicle lowering to access height? My wife’s Velar does it as well.
25th Nov 2024 5:46am |
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 89 |
Yep, completely normal. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red) 𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone 𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone |
25th Nov 2024 4:12pm |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 136 |
When the car wakes up, it will self level and get to access height if not already there, ensuring the easiest possible access. This can be cancelled by having a trailer connected or with the previous EAS you could put the car into tight tolerance mode to allow accurate wheel alignment to be done.
Do the suspension a favour and lower to access height as you drive up to your parking spot. It unloads the suspension arms and ensures the bushings aren't being twisted like if you dropped into access height after hitting the park brake. Increases bushing longevity. |
28th Nov 2024 9:30am |
