Home > Modifications & Maintenance (L663) > Aftermarket Fog and DRL's lower bumper
LR Nuts
Bought a set of aftermarket replacement Fogs with added bumper DRLs.
Will fit when weather get better.
PS with these lamps you need to have the loom for front fogs. And be prepared to fit an 'ignition Live' loom (supplied) for DRLs.
Post #1052179 19th Nov 2024 12:43pm
groaner
Australia
Do all cars have the loom and you just need to add a switch?
Post #1052264 20th Nov 2024 4:17am
ruben
Spain
I don't want to kill your illusion, and of course you can do whatever you want with your car. I know these ones and they look very nice, but they are too exposed for my taste. They are more old school D3. I think the original ones also look very good, they are very well done, they are better protected and they are quite effective, considering how ineffective fog lights always are!
enjoy it!👍🏼 Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1052275 20th Nov 2024 9:13am
LR Nuts
NO, not all vehicles have the loom.
These are replacement items, so you need to have the fogs already fitted.
OK, as for the switch.... this is on the left hand stalk (of the steering wheel, next to the 'rear' fog switch) and would need bought again as a replacement, replacing the original stalk. Then you have to check if the 'clock spring (Squib) loom' is present ? in the steering wheel. Then you need a main loom that picks up power/fuse and a relay.
As these are Fogs and DRLs you need a second loom to run the DRLs with a ''ignition feed' (not the same as the headlamp DRLs, as the lower DRLs do not need to turn off whilst Indicating.
It's a BIG task, not for the faint hearted !!!
Post #1052542 22nd Nov 2024 6:27pm
LR Nuts
ruben wrote:
I don't want to kill your illusion, and of course you can do whatever you want with your car. I know these ones and they look very nice, but they are too exposed for my taste........
Ruben, I picked these up BRAND NEW off of eBay (£150) from a guy who bought them and then realised what was involved to fit them.
Projects like these are everyday tasks for me.
You may have seen my post about cutting into the rear lamp cluster and reconfiguring the internal wiring to give rear DRLs (just the outer two square lamps on each side)
Post #1052543 22nd Nov 2024 6:35pm
LR Nuts
off side fitted, but I have just come up with an easier way to wire the Fog ..... and the DRLs.
Will let you know when I have finished .........
.............. to be continued........
Post #1052544 22nd Nov 2024 6:42pm
Zed
Looks worth the effort to me. Very nice. WARNING.
Post #1052546 22nd Nov 2024 7:30pm
BadgerWaz
For the drl's you can simply run a wire to a connection under the bonnet at the fuse-board. I have done this myself for an led I front-mounted. This is a swl not a perm.live so exactly what you need.
You even get a delay after turning the engine off and locking the car (akin to/alongside a home coming illumination).
Also why not wire the fog lights via their own relay with internal switch? You won't need to drive with your front fog lights on unless it's foggy and your headlights are off.
Unless, you're one of the folks that drives everywhere with your front fogs on blinding all the oncoming cars especially with standing-water on the road. In this case the 'on' button needs wiring to some kind of inferno so you self-combust if you choose this function Very Happy
Post #1052547 22nd Nov 2024 7:54pm
LR Nuts
I'm on top of it Thumbs Up Thumbs Up
Post #1052551 22nd Nov 2024 8:03pm
