Home > In Car Electronics (L663) > Meridian (non-surround) - share your best settings !
Page 2 of 2 <12
CincyRovers1
United States
As you can see, I cut little pieces of the Tesa tape and secured it to the honeycomb on the door panel. No more rattle and the tape doesn't obstruct any sound coming from the speaker. Also applied silicone to the tabs that keep the speaker grille in place just to prevent any rattle. And if it has to be removed at some point, the silicone is easy to scrape off.
 đŸđŸŽđŸđŸ 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1052536 22nd Nov 2024 4:00pm
Perfect job, hot glue can be useful too and comes off clean.
It only takes two surfaces near one another with the speaker in the vicinity to start off some resonance, then it just sounds dull like road noise really.
Mr. Green $W33T $0U7H3RN $UG4R
Post #1052538 22nd Nov 2024 4:27pm
CincyRovers1
United States
I used silicone because when it dries, it is still flexible. Plus, I've been told that hot glue sometimes doesn't hold up well over time in the heat. Silicone keeps its properties at temperatures as low as -40°F (-40°C) and 400°F (204°C). đŸđŸŽđŸđŸ 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
Post #1052539 22nd Nov 2024 4:36pm
Very true, I think the doors are some of the most common rattle areas along with the centre dash area.
On a Puma that is, but doors are common with all vehicles and the door and window mechanisms. $W33T $0U7H3RN $UG4R
Post #1052540 22nd Nov 2024 4:55pm
Page 2 of 2 <12
