Home > Technical > Warning light traction control?
Landy49
Hoping someone can help that has had similar issue.
I keeping having this light come up, comes up when ever it wants.
I had it plugged in and it came up with three faults can anyone’s advice what this actually mean and what needs to be done to cure the problem?
Is it a sensor on one of the wheels or is it a sensor in the loom? Is it a case of limitation change one thing and hope?
Many thanks
Post #1049828 26th Oct 2024 8:36am
andy63
Have you cleared the faults.. and it's the same ones that reappear..
Seem more communication based than wheel sensor.. but the yaw rate gets a mention.. may be worth checking it's mounting and connection..
Post #1050095 28th Oct 2024 7:57pm
Landy49
Finally got round to it.
I ordered a new correlation sensor genuine Land Rover one and made no difference the light came on after 15miles.
andy63 mentions the yaw rate where is the yaw sensor located hoping someone can advise so I can check connection?
Post #1052443 21st Nov 2024 5:31pm
Zed
My 2.4 started doing the same this week. It pops up for a second then disappears after start up and very occasionally while driving. WARNING.
Post #1052444 21st Nov 2024 5:42pm
Landy49
When mine comes up when ever it wants to stays on and if I turn the vehicle off and then on straight away it stays on. But if left for a little while when on start up it does not appear
It doesn’t affect the driving or anything just annoying as it should not be illuminated
Post #1052446 21st Nov 2024 6:23pm
Ianh
Unfortunately if it comes up during an mot it will be a fail as well Sad
Post #1052447 21st Nov 2024 6:46pm
jst
Mines been on loads today..... Very Happy Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1052456 21st Nov 2024 7:43pm
andy63
Ive never looked at the yaw rate sensor but I'm pretty sure my ws manual shows it on the top of the transmission tunnel in front of the gear stick.. but I've read that it is under the drivers seat as well..
Hopefully someone will be able to tell you..
You say you have replaced something already..what is the correlation sensor?
Post #1052463 21st Nov 2024 9:14pm
Landy49
Yes I replaced the correlation sensor hoping that was going to be the cheap and easy solution
Post #1052464 21st Nov 2024 9:32pm
Ask Alive Tuning or BAS, they will be able to no doubt advise you on it more.
Online search of the fault codes can be helpful, as the chances are as mentioned already others have experienced it.
A nuisance code possibly, but if DTC cleared and part replaced then there might be an issue with electrical contacts or similar fault.
It’s cold weather, Zed has mentioned that similar activity has happened there so that’s coincidental.
Voltage below expected values, ambient temps affecting connectors and pins etc and things like that.
With code removed after installation of new part, it shouldn’t reoccur though… TheThunder Rolls🇬🇧🇺🇸
Post #1052466 21st Nov 2024 10:08pm
Landy49
Since replacing the correlation sensor I have not had the fault cleared.
But I want to see the connections to the Yaw sensor and that appeared in the
error codes as well
if someone can please direct me where that is positioned I can check them?
Post #1052482 22nd Nov 2024 7:52am
Landy49
Unfortunately I still have this light come on but it permanently on now and it doesn’t seem to matter on the weather temp like some advised.
Just thought I would bring this forward again in case anyone had any other ideas? And if anyone could advise what I could do before taking it to a garage.
Where is the Yaw sensor located on a 2.2 90, just so I can check connections as well?
Any help would be greatly appreciated
Post #1063101 17th Mar 2025 6:38am
andy63
I mentioned above that I had seen ref to the location of the yaw rate sensor but can't confirm from practical experience..
A shot from a ws manual..
Post #1063106 17th Mar 2025 8:08am
Landy49
Thanks that’s a great help with the picture I can have a look now hopefully it is that
Post #1063112 17th Mar 2025 8:55am
Landy49
Do not suppose anyone has any practical experience getting the the Yaw sensor that could advise please.
Or a written step by step how to do it? I do not seem to find the WS manual to view the picture andy63 has posted for me
Post #1063119 17th Mar 2025 10:22am
