Home > Technical > Warning light traction control? |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 546 |
Have you cleared the faults.. and it's the same ones that reappear..
Seem more communication based than wheel sensor.. but the yaw rate gets a mention.. may be worth checking it's mounting and connection.. |
28th Oct 2024 7:57pm |
Landy49 Member Since: 29 Feb 2024 Location: Hampshire Posts: 46 |
Finally got round to it.
I ordered a new correlation sensor genuine Land Rover one and made no difference the light came on after 15miles. andy63 mentions the yaw rate where is the yaw sensor located hoping someone can advise so I can check connection? |
21st Nov 2024 5:31pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3326 |
My 2.4 started doing the same this week. It pops up for a second then disappears after start up and very occasionally while driving. WARNING.
This post may contain sarcasm. |
21st Nov 2024 5:42pm |
When mine comes up when ever it wants to stays on and if I turn the vehicle off and then on straight away it stays on. But if left for a little while when on start up it does not appear
It doesn’t affect the driving or anything just annoying as it should not be illuminated |
21st Nov 2024 6:23pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2048 |
Unfortunately if it comes up during an mot it will be a fail as well
21st Nov 2024 6:46pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8084 |
Mines been on loads today..... Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
21st Nov 2024 7:43pm |
Ive never looked at the yaw rate sensor but I'm pretty sure my ws manual shows it on the top of the transmission tunnel in front of the gear stick.. but I've read that it is under the drivers seat as well..
Hopefully someone will be able to tell you.. You say you have replaced something already..what is the correlation sensor? |
21st Nov 2024 9:14pm |
Yes I replaced the correlation sensor hoping that was going to be the cheap and easy solution
21st Nov 2024 9:32pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20472 |
Ask Alive Tuning or BAS, they will be able to no doubt advise you on it more.
Online search of the fault codes can be helpful, as the chances are as mentioned already others have experienced it. A nuisance code possibly, but if DTC cleared and part replaced then there might be an issue with electrical contacts or similar fault. It’s cold weather, Zed has mentioned that similar activity has happened there so that’s coincidental. Voltage below expected values, ambient temps affecting connectors and pins etc and things like that. With code removed after installation of new part, it shouldn’t reoccur though… No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
21st Nov 2024 10:08pm |
Since replacing the correlation sensor I have not had the fault cleared.
But I want to see the connections to the Yaw sensor and that appeared in the error codes as well if someone can please direct me where that is positioned I can check them? |
22nd Nov 2024 7:52am |
