Home > Puma (Tdci) > Mixing coolant brands? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
Provided itโs the same colour:
https://www.opieoils.co.uk/p-903-motul-aut...o-use.aspx Meets LR specs, this is what I have in the entire system, pour and go. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
21st Nov 2024 10:15am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2415 |
Those caps fail. It is better to replace it with an Iveco cap (p/n 99489567).
Just the other day I was comparing the cooant composition between a Ford orange jug and a Valvoline zerex? Both are specific for Ford/LR spec but they are not identical. So at this point I am not sure if I would mix them. Puma 110" SW ............................................................. Earth first. Other planets later |
21st Nov 2024 11:10am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2000 |
Donโt go on the colour of the coolant, nowadays the colour of the coolant is a very rough guide. Go on the specification of the coolant.
So If the coolants to be mixed are of the exact same specification, I.e WSS-M97B44-D then yes itโs ok to mix. |
21st Nov 2024 11:23am |
OAT Coolant I believe, and spec that meets the above code.
IIRC the original colour always was orange, it was on mine for an earlier 2.4. Was it changed at all? Texaco XLC is in the manual from the factory. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
21st Nov 2024 11:43am |
johnnymarrsbarres Member Since: 03 Oct 2024 Location: UK Posts: 5 |
Thanks all.
On closer inspection I reckon it's leaking from both the cap and the white plastic heater control valve thingamajig - see photo, looks like it's dripping a bit of coolant. I've thrown some Halfrauds OAT juice in it and ordered a new cap so will keep an eye on it and see how I go. If it's still losing coolant I'll replace the heater thing, looks easy enough. Click image to enlarge |
21st Nov 2024 1:48pm |
Yes thatโs a leak, I think youโve found your problem there.
Beware of driving it anywhere far because it can become a big leak when up to temperature and pressure, so a good thing you have noticed it. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
21st Nov 2024 4:21pm |
Well I've got a 200 mile drive to do on Saturday morning so I guess we're going on hopes and prayers for now!
I'll get one of these valve thingies ordered. |
21st Nov 2024 4:26pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8026 |
Well rightly or wrongly I have mixed coolants of same colour on my own 110. I personally don't think it makes much odds. I have only done 110k in it so time will tell. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
21st Nov 2024 7:42pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 736 |
I find it weird that two coolants can have the Ford approval but one is orange and the other, pink. If this is the case, how now? Technically the same, yet different. No Better Friend, No Worse Enemy
25th Nov 2024 7:44am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1051 |
Colour means nothing at all. Its the active ingredients OAT HOAT, IOAT, IAT, Ethylene glycol, Propylene glycol etc. There was a moment (a long time ago) where mixing two types could lead to gel forming, but I understand that is very much in the past now.
Topping up with some universal or even distilled water till you have time to sort out a leak is just fine I think, but once the system is good it's worth to drain, flush and refill with one system. Most of the types will work (dissimilar metals and not all that dissimilar between cars!) life expectancy of the fluid is the big differentiator - and brand revenue. If you find you opening up and draining your engine occasionally (as I end up doing) you might as well factor in a fresh fluid refill with whatever suitable Halfords (or Norauto/Carrefour/etc) has on offer every 3 years or so. Where to dispose of the wasted fluid in France I find the bigger challenge, same with waste oil. France recycling efforts have not moved much beyond the 90s. |
25th Nov 2024 8:34am |
