Home > Puma (Tdci) > Mixing coolant brands?
johnnymarrsbarres
 2007 Defender 90 Puma 2.4 SW Cairns Blue
Hi all.
My 2.4 Tdci is low on coolant - I'm fairly sure (hoping anyway) it's the expansion tank cap as there is some wet residue around it and there are no other symptoms - car drives fine, no smoke, no overheating, heater works fine, no mayonnaise in oil filler cap. Coolant is just low.
I've ordered a new OEM filler cap but I need to top up the coolant. Will Halfords standard OAT coolant do the job? And is it ok mixing and matching with whatever's currently in there? The expansion tank is a couple of cm's below the 'cold level' fill line so there is existing coolant in the system, it's just a bit low.
Thanks!
Post #1052391 21st Nov 2024 10:10am
Provided it’s the same colour:
https://www.opieoils.co.uk/p-903-motul-aut...o-use.aspx
Meets LR specs, this is what I have in the entire system, pour and go. Chillin In The Backwoods🇬🇧🇺🇸
Post #1052394 21st Nov 2024 10:15am
MK
Those caps fail. It is better to replace it with an Iveco cap (p/n 99489567).
Just the other day I was comparing the cooant composition between a Ford orange jug and a Valvoline zerex? Both are specific for Ford/LR spec but they are not identical. So at this point I am not sure if I would mix them. Puma 110" SW
Post #1052396 21st Nov 2024 11:10am
Ianh
Don’t go on the colour of the coolant, nowadays the colour of the coolant is a very rough guide. Go on the specification of the coolant.
So If the coolants to be mixed are of the exact same specification, I.e WSS-M97B44-D then yes it’s ok to mix.
Post #1052398 21st Nov 2024 11:23am
OAT Coolant I believe, and spec that meets the above code.
IIRC the original colour always was orange, it was on mine for an earlier 2.4.
Was it changed at all?
Texaco XLC is in the manual from the factory. Chillin In The Backwoods🇬🇧🇺🇸
Post #1052402 21st Nov 2024 11:43am
johnnymarrsbarres
Thanks all.
On closer inspection I reckon it's leaking from both the cap and the white plastic heater control valve thingamajig - see photo, looks like it's dripping a bit of coolant.
I've thrown some Halfrauds OAT juice in it and ordered a new cap so will keep an eye on it and see how I go. If it's still losing coolant I'll replace the heater thing, looks easy enough.
Post #1052419 21st Nov 2024 1:48pm
Yes that’s a leak, I think you’ve found your problem there.
Beware of driving it anywhere far because it can become a big leak when up to temperature and pressure, so a good thing you have noticed it.
Thumbs Up Chillin In The Backwoods🇬🇧🇺🇸
Post #1052435 21st Nov 2024 4:21pm
johnnymarrsbarres
Well I've got a 200 mile drive to do on Saturday morning so I guess we're going on hopes and prayers for now!
I'll get one of these valve thingies ordered.
Post #1052437 21st Nov 2024 4:26pm
jst
Well rightly or wrongly I have mixed coolants of same colour on my own 110. I personally don't think it makes much odds. I have only done 110k in it so time will tell. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1052455 21st Nov 2024 7:42pm
HardCharger
I find it weird that two coolants can have the Ford approval but one is orange and the other, pink. If this is the case, how now? Technically the same, yet different. Shocked No Better Friend, No Worse Enemy
Post #1052849 25th Nov 2024 7:44am
TexasRover
Colour means nothing at all. Its the active ingredients OAT HOAT, IOAT, IAT, Ethylene glycol, Propylene glycol etc. There was a moment (a long time ago) where mixing two types could lead to gel forming, but I understand that is very much in the past now.
Topping up with some universal or even distilled water till you have time to sort out a leak is just fine I think, but once the system is good it's worth to drain, flush and refill with one system. Most of the types will work (dissimilar metals and not all that dissimilar between cars!) life expectancy of the fluid is the big differentiator - and brand revenue. If you find you opening up and draining your engine occasionally (as I end up doing) you might as well factor in a fresh fluid refill with whatever suitable Halfords (or Norauto/Carrefour/etc) has on offer every 3 years or so.
Where to dispose of the wasted fluid in France I find the bigger challenge, same with waste oil. France recycling efforts have not moved much beyond the 90s.
Post #1052851 25th Nov 2024 8:34am
