Ianh
lightning wrote:Thank you for the information.
Maybe l would be better looking for a 2.4 Puma. There's plenty of those about and they're cheaper.
A 2.4 Puma would be far better than a 2.2 Puma for your driving pattern (no DPF ). If you can find a good condition well looked after one with medium to low mileage it will serve you well for many years. Noting as with any classic defender you do need to keep on top of regular maintenance, which is not just a service every 12 months.
20th Nov 2024 11:44am |
Chicken Drumstick wrote:If you only do 2-3 miles in a day, maybe as two journeys hours apart, likely more of an issue.
Exactly this, especially with a 2.2, but the less desirable factor is in these circumstances it can and will occur it depends on what you need and when, so is a bit of a pain.
Which is why I like the 2.4 more and am of course admittedly bias, but overall shouldn’t be too much of an issue really except the DPF itself is very costly. WeWillWin🇬🇧🇺🇸
20th Nov 2024 11:46am |
Julie
lightning wrote:l've currently got a new (2022) Defender 3.0 diesel and that copes with it fine, done 17,000 miles over two years and had no issue at all.
But the new one has been designed around the DPF and it's known not to give issues.
The 2.2 Ford engins are also designed around the DPF
Injectors EGR DPF really are reliable.
The only issue, I do really see, is that you can't buy a new one like your 2022 Defender. A 10 year old truck is perhaps not the best choice for professional use
24th Nov 2024 9:15pm |
