![]() | Home > Puma (Tdci) > TDCi heater control valve options |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Porny, whens the next batch due? NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2260 ![]() ![]() |
So do you have better control of the heat level via the control on the dash. Or is it like the Original LR one , i.e more or less on full heat or no heat with nothing much in between. |
Tim300TDIMorts Member Since: 04 Jan 2017 Location: Chandlers Ford Posts: 108 ![]() ![]() ![]() |
Sorted it. I hadn’t fixed the cable in place. Ha |
Dio Member Since: 21 Nov 2024 Location: Nicosia Posts: 2 ![]() ![]() ![]() |
Dear materoforion, It is my first time in the group after not solving the heater valve problem. how is your heater valve going so far? Could you make a video of your modification? The Intergrated 316 valve is stanning but far too expensive and not in stock yet Thank you |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 206 ![]() ![]() ![]() |
There are two issues with the stock heater valve. They can develop leaks and they don't fully seal the passages either when fully open and/or fully closed. Leaks are an obvious issue. Not fully closing is only apparent in either very warm or very cold weather.
I have bought aftermarket valves, genuine valves and genuine valves from FIAT and others. The aftermarket valves are the worst but none of them actually seal completely. I have also purchased the AC heater valve pictured above. It is originally off a Ford. I have bought both aftermarket and OEM. They also don't completely seal at either extreme. Does it matter? At -30 or +30 it sure as %$# does. What I'm experimenting with right now is using a brass, 4-way, L-gate, ball valve. They seal so well you can apply a strong vacuum and there are still no leaks. The big plus is that the valves are cheap. I bought two for $40/£20 off amazon. It is all unalloyed joy? Of course not. The secure seal also means that the lever is stiff to move so you can't use the stock, plastic control. I'm fitting a vernier bowden cable from an aircraft supplier. I'll post photos as I go along... Last edited by jbcollier on 22nd Nov 2024 1:07am. Edited 1 time in total |
Valve as purchased:
![]() Click image to enlarge Modified: ![]() Click image to enlarge Last edited by jbcollier on 21st Nov 2024 6:41pm. Edited 1 time in total |
Good job, please keep us posted and for the cable as well
![]() Click image to enlarge I finished the valve and have it installed without the cable. Works good. This is a valve with 5/8" fittings. I have ordered one with 3/4" fittings as I think that will fit the hoses better. No leaks, mind, just want it to be fit and forget with the stock clamps. I had to fit adjustable clamps to two of the fittings. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
just check your antifreeze and metals compatability with the brass DEFENDER 90 TDCI XS,
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
I think some London black cabs use a brass hcv. WARNING.
This post may contain sarcasm. |
I've got it all in and it works just fine. May not fit a separate control cable. Going to explore fitting a spiral return spring first.
It's not an easy conversion as you do a fair bit of silver-soldering. If I was doing it again, I just buy the high-zoot, fabricated valve. Was interesting exploring and testing all the options. |
Owen_91 Member Since: 11 Jun 2024 Location: Southampton Posts: 3 ![]() ![]() ![]() |
Bump again for this thread - the integrated316 website is showing delivery expected March 2025 (now?). Are these still on track?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
In case it is of interest to anyone, last week my heater valve failed, the second in 18 years, in exactly the same way as the original one did several years ago, namely it became impossible to turn the hot water flow off (the lever moves freely but something inside the valve has broken). Nothing leaked, it just wasn't possible to turn the heat off.
I have had a second-hand genuine valve in the spares box since the last failure which I fitted, but to replace the spare I ordered up one of the cheap Chinesium ones from Ebay for about £28. It arrived very quickly and seems to be every bit as good in terms of quality as the original (whichI acknowledge is not setting the bar very high since the originals are frankly embarrassing). It works perfectly when subjected to the "blow" test. Time will tell if it durable but since it was roughly one quarter the price of an original piece of plastic junk if it lasts even half the time it is still a winner. Fitting it took all of 5 minutes, involved negligible loss of coolant, and required no innovative engineering. |
A question to those that have fitted ian’s ( porny on here) IRB / Integrated 316 heater valves ( made for him by design and development engineering I believe).
Do you have better control of the heat level via the control on the dash ? Or is it like the Original LR one , i.e more or less on full heat or no heat with nothing much in between ? |
