Home > Tdi > Delphi "look-alike" lift pumps? |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 497 |
I fitted a look alike to my tdi 200, because it seemed to be leaking, but was working, it must have lasted six months before the pin inside snapped rendering it useless. I fitted a Delphi one, same results. I then bought a second hand genuine one, which was fine. New parts are very often worse than old ones! 1983 110 automatic OM606
18th Nov 2024 8:42am |
julian Member Since: 17 Feb 2017 Location: Devon Posts: 134 |
I've got one of the hs2.8 engines (the 300tdi clone).
That uses the same lift pump setup, but requires a custom pump, as the 300 ones don't fit. And the custom one is £100 a hit rather than £25 and break just as quick. I gave up in the end and fitted a little electric one. Which is what I should do to the 300 really. |
18th Nov 2024 8:49am |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 632 |
I have run 300’s for longer than I can remember, I’ve had at least twenty of them, only ever had one pin snap abut fifteen years ago on a genuine pump which had been on vehicle from new, although would be a shame if the Delphi is unavailable as the internal cleanable filter is a big improvement over the original.
19th Nov 2024 4:16am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2269 |
This is why I moved to an electric pump when my 90 had the 200 in it. It's easy to do and you won't miss changing lift pumps 😁
19th Nov 2024 9:08am |
If I do it, I'll use one of the little black faucet pumps.
They do one with a clear pre-filter bowl, but that one is not compatible with biodiesel (I suspect it's the clear bowl that would die) so I'll probably just fit a stainless mesh pre filter from eBay / Ali express etc (they're all the same) It would be fine, but every part always comes with a different thread type so you end up having to buy odd adapters etc etc and, whilst it won't be costly, it will take a while. ...which is whats putting me off! |
19th Nov 2024 9:46am |
zeerover Member Since: 11 Jan 2009 Location: Ghent Posts: 17 |
This is the second new 200tdi fuel lift pump failing after a short period. I always buy the STC1190G and get the blue box with the pump unbranded. The first was leaking, the second too and did mij engine cut off. Where can i find the branded pumps ETC6180G, ETC7868G or STC1190G.
9th Dec 2024 9:27am |
