Home > Puma (Tdci) > Intermittent power power loss 2.4tdci |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1991 |
Have you changed the VCV ? Do you get any Diagnostic Trouble Codes (DTC’s).
16th Nov 2024 10:01pm |
Defender du Member Since: 20 Feb 2024 Location: Wales Posts: 17 |
Vcv would of been changed a couple of years ago, not getting erratic tick over so thought it would not be VCV as it sits well on tick over.
16th Nov 2024 10:06pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17353 |
Check for DTCs and if none change the VCV.
16th Nov 2024 10:42pm |
Thanks have got one on standby after lastime👍
17th Nov 2024 6:48am |
Click image to enlarge These are the Dtc |
17th Nov 2024 7:25am |
Given you have changed the injectors and the fuel filter, what’s the wiring like to the injectors ? as I’m thinking the P121C code is pointing to the culprit.
17th Nov 2024 4:07pm |
Thanks Ian will have a look👍👍
17th Nov 2024 4:28pm |
Trev Member Since: 01 Jul 2023 Location: Fife Posts: 8 |
I had a similar issue with mine, I would be trundling along and it would just lose power and acceleration would be extremely sluggish. If I pulled over, switched the engine off then on again the problem would go away for a while. In my case it was the turbo actuator that was at fault.
17th Nov 2024 9:03pm |
Actuator seams ok have been putting some light oil for a few months and there is movement. The problem happens when you put your foot down and it is like limp mode. If I pull over and try to rev struggles to go above 2000rpm.
17th Nov 2024 9:22pm |
