Home > Maintenance & Modifications > Sunroof seals
johnnymarrsbarres
 2007 Defender 90 Puma 2.4 SW Cairns Blue
Sunroof seals
Hi all
I have a 2007 Tdci 90 with what I assume is the factory fitted sunroof with the twist handle. The previous owner has gaffer taped it shut, presumably because it leaks.
I'm taking the car to get its roof painted in a couple of weeks, so I thought I'd take the opportunity to ask them to replace the sunroof seals with a new one while they're at it.
The thing is I don't know which seal is leaking, looks like there's a couple of them.
I'm looking on the LR parts website for seals and looks like there are two replacement kits available:
https://www.lrparts.net/awr3320-sunroof-to...-2016.html
https://www.lrparts.net/lrc10106-twist-han...patch.html
They look the same to me...can anyone help/advise?
Thanks!
Post #1051724 14th Nov 2024 12:24pm
Give the seal a good smear in vaseline as well. I did that on my 110 and it stopped it leaking.
I then didn't open it for about 6 years afterwards.
Post #1051770 14th Nov 2024 8:38pm
Oldowner
In the past I have removed the sunroof and refitted it down on decent sealant, has been completely dry for nine years now. It’s fairly easy to do, remove the rubber felt seal to reveal on the fixing screws, unscrew the bottom section from the top section and re seal.
Post #1051883 16th Nov 2024 10:56am
johnnymarrsbarres
Hi all.
On my sunroof seal conundrum.
The hinges were knackered and not even screwed in properly, so I’ve replaced those. Easy enough job.
I’ve also replaced the seal. I’m finding though that while I think it’s seated properly, the sunroof glass wants to ‘tuck’ in at the front, but sit on top at back. This doesn’t look right to me.
See photos attached. Am I doing something obviously wrong here?
Thanks all.
Post #1054244 9th Dec 2024 3:05pm
