Home > Puma (Tdci) > Inlet manifold seals
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
Is it necessary to replace the seals on the inlet manifold if I remove it for decoke/inspection? Seen some reuse them or every time you disturb the seal they should be replaced?
Post #1051449 12th Nov 2024 5:20pm
spudfan
Ireland
I had a leak in one of mine and it was easy enough to replace. The independent I used recommended replacing with new seals once removed. If refitting the existing one just make sure you do not damage the removed seal in any way.
Just remembered. When fitting the seals he smeared around the area with something on his finger. Cannot remember what it was but it was in a little tube. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1051455 12th Nov 2024 5:58pm
Ianh
On my 2.2 I had to disconnect the inlet manifold and move it down 20mm to replace my glow plugs. I did not have room to fully remove it without removing more components so I just refitted it with existing seals and all has been ok.
Post #1051513 12th Nov 2024 9:33pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Do you have to? Probably not. Is it a good idea? Yes. You are in there and there seals are cheap.
Post #1051539 12th Nov 2024 11:35pm
