Home > Puma (Tdci) > Disconnect battery |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1429 |
I've not had any problems with the immobiliser, but disconnecting the main battery may trigger the battery backup alarm sounder. It won't stop until it either the backup looses it's power or the main battery is reconnected and alarm reset.
Detail of how to stop that here: Disconnect the battery within 17 seconds of turning ignition off and remove the key |
9th Nov 2024 11:27am |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 808 |
9th Nov 2024 12:30pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2169 |
in general as long as the ignition has been active then there will be no issues or alarm activation when you then disconnect the battery..........
open truck, key in ignition and illuminate warning lights, key off and then disconnect |
9th Nov 2024 12:38pm |
