Home > Modifications & Maintenance (L663) > Led light bar install
Page 2 of 2 <12
Telemarkskier
The premium headlights high beam is via CANBUS signal. To get your lightbar to work in auto mode you need an interface to be fitted and connected.
I went without as I was short of £££s at the time of fitting so just use the manual high beam stalk, 2020 Defender 110 SE 240D: Fuji White.
2011 Freelander 2 SD4 HSE
2007 Freelander2 HSE (man)
Post #987562 1st Apr 2023 3:24pm
Buz1500
Yes, I had this confirmed by Lazer Lamps.
I decided that the current operation, via the manual High beam selection is actually my preferred option. 2019 Range Rover SDV8 Autobiography
2023 Defender 110 P400e X-Dynamic HSE - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #987567 1st Apr 2023 3:44pm
91dm
Ireland
Just looking through old threads for light bars, does the light bar above actually make a noticeable difference?
I'm looking for one that looks good but actually improves visibility.
Post #1051018 7th Nov 2024 8:10pm
Buz1500
I don’t have the car anymore but I can confirm that the light output was phenomenal. 2019 Range Rover SDV8 Autobiography
Post #1051020 7th Nov 2024 8:13pm
91dm
Ireland
Thanks Buz1500. Really? I can't see any lumen output or spec of the lights so started to think they're just for show.
Think I'm going to order one so and the canbus sensor.
Post #1051022 7th Nov 2024 8:21pm
Buz1500
I had the linear elite 18, 21000 lumens.
Try this link to view the lights
https://www.lazerlamps.com/lights/linear.html 2019 Range Rover SDV8 Autobiography
Post #1051026 7th Nov 2024 8:44pm
Buz1500
I would also add that mine was mounted on the front grill using the integration kit sold by Lazer Lamps.
https://www.lazerlamps.com/land-rover-defe...ar-18.html 2019 Range Rover SDV8 Autobiography
Post #1051051 8th Nov 2024 9:15am
91dm
Ireland
Thanks, good to know!
Post #1051115 8th Nov 2024 9:26pm
haymeister
Japan
Was it an easy install? how long, any special tools required? 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #1051390 12th Nov 2024 6:15am
Page 2 of 2 <12
