![]() | Home > General & Technical (L663) > Gearbox Issues on 23MY V8 110 Carpathian |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2917 ![]() ![]() |
Warped brake discs are common, it doesn't mean it's been driven hard. Mine warped and l've only ever driven "normally"
Before you do anything else, get the transmission oil level checked. l was told by an independent LR specialist that they are sometimes delivered with a slightly low oil level. And you can try resetting the gearbox parameters. Look it up. After that if you're still not happy then maybe see if you can get a test drive in another V8 to see what that is like. |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 288 ![]() ![]() |
My 23.5 V8 90 doesn't do as you describe, it's very smooth at motorway speeds including when changing down at power for any reason. 23.5MY 90 V8 Carpathian grey
