Home > General & Technical (L663) > L663 110 rear suspension
peanutbob
Iโ€™m 14k miles into my 2nd L663 110. The last one I p/exed at 19k miles without issue.
I am aware that on uneven roads, rippled tarmac, dried mud etd there is a squeak/chirrup from the rear suspension which has occurred over the last 2 weeks. Possibly rear shocks ..the ride seems firmer. Iโ€™ve changed from comfort to auto settings, adjusted height up and down, but to no avail.
Iโ€™ll have to take it in to a dealer for investigation but if anyone has experienced this issue please advise!
Thanks .
Post #1050929 6th Nov 2024 9:04pm
CincyRovers1
United States
Is it a rattle? If you're on air suspension, it could be the rear shock tower bolts. They are known to become loose if you do a lot of off-roading or if you drive on a lot of rough pavement. This is only on cars with air suspension. See the attached threads on the Land Rover Forums site.
https://landroverforums.com/forum/2020-def...mi-117301/
https://landroverforums.com/forum/2020-def...ts-123759/ ๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐ƒ๐ž๐Ÿ๐ž๐ง๐๐ž๐ซ ๐Ÿ๐Ÿ๐ŸŽ ๐’ ๐๐Ÿ‘๐ŸŽ๐ŸŽ (Pangea Green over Acorn/Lunar)
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ‘ ๐๐จ๐ซ๐ฌ๐œ๐ก๐ž ๐Œ๐š๐œ๐š๐ง ๐’ (Dolomite Silver over Black/Bordeaux Red)
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ• ๐ƒ๐ข๐ฌ๐œ๐จ๐ฏ๐ž๐ซ๐ฒ ๐‡๐’๐„ ๐‹๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐’๐ข๐Ÿ” (Aintree Green over Vintage Tan/Ebony) - Gone
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐‹๐‘๐Ÿ’ ๐‡๐’๐„ ๐Ÿ“.๐ŸŽ (Ipanema Sand over Almond/Arabica) - Gone
Post #1050933 6th Nov 2024 9:39pm
peanutbob
Well it could be! Doesnโ€™t quite sound like the video a bit more muffled but then theyโ€™re covered over in the back whereas they are exposed in the clip.
Very good starting pointโ€ฆIโ€™ll have a look tomorrow morning . Thanks
Post #1050936 6th Nov 2024 9:53pm
