Home > Td5 > Defender 90 TD5 front door card
Lunar Landy
United Kingdom 2003 Defender 90 2.5 TD HT Bonatti Grey
Hi All,
I’ve just purchased some door fixings to fit the door card, can anyone identify where this part fits?
I can’t see what the spigot and cover does?
Thanks
Post #1050875 6th Nov 2024 9:55am
markb110
Hi
There are two per each front door.
One goes into the top corner nearest the hinge and the other in the bottom corner diagonally from the first.
The clear ( sometimes white plastic ) is tapped into the door, and the black part goes through the door trim when in place and the shaft tapped until flush.
Hope that helps
Disclamer, from memory……now where did I leave my keys again… Whistle
Post #1050879 6th Nov 2024 10:41am
Lunar Landy
Hi Markb
Am I correct in thinking the spigot is cut off once tapped home?
The photo is what was in before
Thanks
Post #1050890 6th Nov 2024 11:41am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
You are correct, and what was in before is incorrect for OE fitment but if it works 🤷‍♂️
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1050895 6th Nov 2024 1:17pm
Screbble
Lunar Landy wrote:
Hi Markb
Thanks
You don’t need to cut anything off - just tap in flush
Post #1050924 6th Nov 2024 7:53pm
Screbble
Re: Defender 90 TD5 front door card
Lunar Landy wrote:
Hi All,
Thanks
The transparent part fits in the metal door skin, the plastic piece fits through the door card, and the plastic pin is tapped flush.
Post #1050926 6th Nov 2024 7:55pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
After lot od broken plastic clips on door cards I have switched to rivnuts in doors and strainless screws with some nice heads. It really holds the doorcards to doors. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1050950 7th Nov 2024 10:17am
Just be careful the SS doesn’t seize there with the Rivnut, so a little anti seize is ideal. Thumbs Up KEEP CALM AND Drill ON
Post #1050984 7th Nov 2024 2:07pm
