Home > Td5 > Defender 90 TD5 front door card |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2653 |
Hi
There are two per each front door. One goes into the top corner nearest the hinge and the other in the bottom corner diagonally from the first. The clear ( sometimes white plastic ) is tapped into the door, and the black part goes through the door trim when in place and the shaft tapped until flush. Hope that helps Disclamer, from memory……now where did I leave my keys again… |
6th Nov 2024 10:41am |
Lunar Landy Member Since: 02 Jun 2023 Location: Northamptonshire Posts: 39 |
Hi Markb
Am I correct in thinking the spigot is cut off once tapped home? The photo is what was in before Click image to enlarge Thanks |
6th Nov 2024 11:41am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 956 |
You are correct, and what was in before is incorrect for OE fitment but if it works 🤷♂️
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
6th Nov 2024 1:17pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
You don’t need to cut anything off - just tap in flush |
6th Nov 2024 7:53pm |
The transparent part fits in the metal door skin, the plastic piece fits through the door card, and the plastic pin is tapped flush. |
6th Nov 2024 7:55pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 637 |
After lot od broken plastic clips on door cards I have switched to rivnuts in doors and strainless screws with some nice heads. It really holds the doorcards to doors. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
7th Nov 2024 10:17am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20590 |
Just be careful the SS doesn’t seize there with the Rivnut, so a little anti seize is ideal. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
7th Nov 2024 2:07pm |
