Home > Td5 > Reverse trigger
landy andy
Reverse trigger
Where are people finding a reverse trigger for reverse camera/monitor?
About to go double din, and camera so need a connection onto the reverse connection ideally as near to the head unit as possible.
Although part of me is thinking of just put a switch in.
Thanks
Andy.
Post #1050827 5th Nov 2024 5:52pm
Reversing light switch on gearbox.
Post #1050844 5th Nov 2024 8:05pm
landy andy
That’s what I thought Big Cry
Was hoping there to be something inside, or even bulkhead.
Post #1050849 5th Nov 2024 8:59pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
You can also tap into the reverse light at the back. I used the continuous power back there and the reverse light as the trigger.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1050896 6th Nov 2024 1:21pm
As above you can take it from the rear. (If you want to & prevents damaging factory wiring).
If you’d like to have a plug and play option, you may wish to contact PaulMC on here to help with that.
He is a great guy to deal with, and very knowledgable. Thumbs Up
You can run the cable behind the headlining and down A pillar with 1mm2 thinwall. Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1050898 6th Nov 2024 1:35pm
landy andy
Mmmm. So a switch then. Rolling with laughter Rolling with laughter Rolling with laughter
Post #1050922 6th Nov 2024 7:44pm
You can if you want, I have mine on all the time that the HU is on, and will auto pop up on screen if the reverse is selected.
That way you can select the camera any time as it’s on anyway, but will still come on screen when reverse is selected. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1050925 6th Nov 2024 7:54pm
DSC-off
Or just plug this into the reverse light to supply the camera and extend it forward to the headunit.
https://www.mudstuff.co.uk/collections/wir...iring-loom
Post #1050934 6th Nov 2024 9:41pm
