Home > Puma (Tdci) > ABS and TC not working |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 33 |
The lights should come on as a bulb check on ignition. If it was one light not coming on a failed bulb could of course be the problem, but for all three to have failed is not probable. Also it seems the ABS is not working so that would mean the light should be constantly on, maybe also the TC light. In Sweden this would be a MOT failure. That could be a motive to hide the light. Although the bulb check would also be a fail if the light didn't come on. The same goes for the Check Engine light.
I don't understand the fault codes but are they connected to engine/emission management? Could they trigger the Check Engine light? Seatbelt light? Never seen in a Defender, but yes the symbol is there, but there is no system for it. |
4th Nov 2024 8:00am |
Guisalla Member Since: 02 Nov 2024 Location: Sao Paulo Posts: 6 |
News from my Defender... =[
Today i took the car to a specialized place, and they found that the previous owner reprogrammed the car's modules precisely so that no light errors would appear. Now they need to restore the configurations of the car, and after that have a correctly read errors and problems. |
4th Nov 2024 11:33pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 496 |
Why not follow the last option and remove ABS. The stuff is 15 years old and I wonder if all parts were still available... |
6th Nov 2024 1:43pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 740 |
I've recently been contemplating this. Or at least installing an off switch to disable it when it's causing issues like it is with my truck at the moment. Doing the 10 steps on the brake pedal before starting does not always work apparently.
I wonder though if disabling the TC will affect the performance of ATBs installed. They supposed to work perfectly when working properly. Will just ATBs alone and probably tricky left foot braking be sufficient to overcome no TC? No Better Friend, No Worse Enemy |
7th Nov 2024 2:49am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8049 |
left foot cadence is what we used before TC to help get the best from ATBs, theory still works. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Nov 2024 12:00pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17427 |
I have ATB diffs and no ABS (thank goodness!) and it works just fine. It is rare - very rare - that any left foot input is required. The Puma does of course also have the annoying feature that if you press both right and centre pedals simultaneously after a second or tow the ECM ignores the throttle input, a real pain if you are trying to dry your brakes. This is a consideration rather than a problem with left-foot braking and the ATBs, I have never had to apply LFB for traction purposes long enough to shut down the throttle. |
7th Nov 2024 1:06pm |
Since my truck has ABS / TC any way to disable without the ECU and instrument cluster getting mad at me? No Better Friend, No Worse Enemy
8th Nov 2024 4:37am |
