Home > Puma (Tdci) > ABS and TC not working
Guisalla
Brazil 2007 Defender 110 Puma 2.4 SW Stornoway Grey
Hello Everyone,
Greetings from Brazil!
I just bought my 2007 Defender Puma 2.4. I'm very excited about the car, because this is a child dream for me, but i have an issue that is taking out my peace. My ABS and TC is not working and not showing the lights in the cluster when is turned on... Its possible that the previous owner turned off these lights?
There is only the brake light showing in the cluster all the time.
Post #1050501 2nd Nov 2024 1:44am
Bluest
Firstly, is it definitely a model with ABS? Nor all Pumas have it. If it is, the best course of action is to use an OBD code reader that can read codes I the ABS module. 2007 110 TDCi Station Wagon XS
Post #1050507 2nd Nov 2024 7:35am
Guisalla
Thanks =]
Yes, I borrowed from a friend the OBD code reader and scanned the car.. appeared all these errors (sorry, it is portuguese).
The car has the system but with this lot of errors, the lights on the dashboard should be on, right?
Post #1050524 2nd Nov 2024 10:24am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Yes. At least ABS light should come up.
But are you sure that your truck has it installed ?
I believe TC was only available with the BOSCH ABS in the 2.2 TDCI
ABS was not a standard feature. It is not installed on mine.
I don't have an ABS control light. And no error codes.
In my opinion you're having some "modifications"
Post #1050609 3rd Nov 2024 10:14am
TexasRover
Surely a peek under the bonnet and or a glance at one of the front hubs at full lock should indicate if ABS is fitted?
What makes you think ABS is fitted and also what do you mean with the brake warning light is on, is it always on, like in low fluid level on?
Post #1050613 3rd Nov 2024 10:29am
Julie
If ABS fault codes were read, at least the ECU would have been from a Puma with ABS.
But the posted fault codes are rubbish since the first letter is missing.
P0306 = cylinder #6 misfire detected
How does it come to this code ?
Post #1050614 3rd Nov 2024 10:34am
TexasRover
That would explain so may error codes
Post #1050616 3rd Nov 2024 10:55am
Julie
I guess it's the low liquid level you've already mentionned.
The WABCO ABS is proprietary fault coding - not integrated in CAN-BUS standardized coding. A dedicated reader should be used e.g. Nanocom. Many threads exist on faulty WABCO ABS that ceases functions : e.g. 3 amigos 2 amigos here in this forum
https://www.defender2.net/forum/post847243.html
His truck from 2007 may be one of the first ROW Pumas.
I wonder if it has a catalysator and EGR
Post #1050621 3rd Nov 2024 12:13pm
I have a feeling early Pumas only had ABS if they were XS models, they also had or likely had AirCon too, but later 2.2’s were more likely to have ABS and TC.
I mention aircon because XS models have it.
I’m glad mine doesn’t have ABS etc and TC and so on, they commonly go wrong.
The brake light will come on per permanently if the brake fluid is low, but if not it might show up then extinguish after starting.
Any ABS or TC lights, should extinguish after starting, possibly illumination if active then off again.
So if you were driving along and the TC activates, then I believe it may come on while active.
Mine doesn’t show any ABS or TC lights on the dash, and doesn’t have it fitted.
So if there is those lights on the dash, then if they don’t extinguish after starting, then there is a fault.
Post #1050641 3rd Nov 2024 4:35pm
Guisalla
Hello Everyone!!
Thanks for all the information..
Yesterday I spent all my day trying to figure out what is happening.. Here are some things that I found:
- My car has the ABS system and WABCO ECU. (All pieces have the sticker 2007, which is the same year of the car)
- I took off the cluster and found some cables with electrical tape, so I think this is an old problem.
- There is missing more 2 lights: Seat bealt and Engine.
- I checked all the fuses, and are all good.
So I think I will have big problems to solve...
Post #1050659 3rd Nov 2024 8:19pm
jst
Wabco/siemens is correct upto 2010my. It then was a bosch unit.
Does the TC/abs actually work? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1050660 3rd Nov 2024 8:40pm
Guisalla
Not working =[
I did a test just pushing hard de break and locked hard.
Post #1050662 3rd Nov 2024 8:53pm
Julie
Do you have the "2 amigos" or the "3 amigos" in your WABCO system ?
Do a forum search or follow the link I've posted ...
Post #1050666 3rd Nov 2024 9:38pm
Guisalla
Problably yes, i have the 3 or 2 amigos...
But the strange thing is that the engine light, seat belt light, ABS and TC lights aren't showing up when i turn on... (and the signal when pass above 120km/h isnt working)
I think someone tried to hide this lights, and i don't know if its possible.
Post #1050669 3rd Nov 2024 10:40pm
Julie
If you're sure that the ABS doesn't work (and no Amigo), you will have 3 différent ways to proceed :
1) return the truck to the seller
2) get the right fault codes and repair
3) remove ABS/TC from your truck and make your truck conform to Defenders without these features
Post #1050687 4th Nov 2024 7:45am
