![]() | Home > For Sale & Wanted > [Wanted] Single phase motor |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
I imagine that you've considered and rejected the idea of using the existing motor with a VFD?
I recently changed my Bridgeport mill back to it's original 3ph motor with a VFD and wish I'd done it years ago. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1677 ![]() ![]() ![]() |
Yeah I’d go for a VFD as well.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3480 ![]() ![]() ![]() |
As above. Their prices are so good nowadays. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3698 ![]() ![]() ![]() |
I have been thinking about vfd, but I want to keep it as traditional as possible. I realise that is just nostalgic nonsense, but a 70 year old drill with electronic seems a bit wrong! Also, when I reduce the frequency it will also reduce torque which will be an issue in some applications.
An excellent ambition but what could be more traditional than the original motor? Using a VFD would mean that absolutely nothing on the drill needed to change, it would simply be connected to an external variable frequency three-phase supply. Perhaps the ultimate in "traditional" other than getting an old-school three-phase supply laid on to your workshop, and even that would mean that you wouldn't get the same degree of speed control. |
Touché Blackwolf, touché!
julian Member Since: 17 Feb 2017 Location: Devon Posts: 143 ![]() ![]() ![]() |
As above, if you want originality, feed it 3ph...
...from a vfd. You don't need to do anything to the drill, just take it's 3ph plug off and fit a suitable vfd on the end of the wire. Be aware that not all vfds are equal. Most motors will run on cheap simple units, but others need "boost" units etc depending on how they're set up. Id imagine your drill will only need a small simple unit. The last one I bought was £40 off Amazon... |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 164 ![]() ![]() ![]() |
This assumes the motor is dual voltage…
As stated, not all VFDs are equal. "boost" units exist, theyre just a bit more money. |
I’d love a link to a £40 one of Amazon if you can? |
I've just looked at my old invoice and it was £53 all in, not the 40 that I incorrectly stated (apologies) however that's not the current price.
This is the link - https://www.amazon.co.uk/gp/aw/d/B07X11HTX...&psc=1 Amazon price goes up and down all the time - I suspect if you look through other sellers there may not be one as cheap as I got it, but there will be someone at an easier price. This was for small motor that could not be run off a standard vfd (I needed the higher voltage output). I forget what I once knew about 3ph motors but if you can run the motor in the, umm, other configuration, you can (probably) use a non voltage increasing unit, and they're cheaper. (This was for the feed motor on a wadkin bao/s) |
This is an exceedingly similar unit for the same sort of price I paid -
https://www.amazon.co.uk/dp/B07TMZT6ZP/ref...V9kZXRhaWw Again, 380v output if you need it, but only for small motors |
Thanks Julian, much appreciated.
Ordered, and got a return version for £40, and another 10% off!! What’s not to like!!
