Home > In Car Electronics > Td5 central lock gone haywire |
SebastianK Member Since: 07 Aug 2020 Location: Copenhagen Posts: 12 |
Hi
I have a late 2001 TD5 110 which I have attached a aftermarket central lock kit on (soldered the wires on the alarm ecu like in this thread https://www.lrukforums.com/threads/land-ro...m.112467/) and also like attached picture. img:1284:629]https://www.defender2.net/gallery/albums/userpics/25431/IMG_0179.jpeg[/img] It seemed to work when I had the original exterior light installed, but when I fitted all LED around, the central locking is now intermittently going haywire. It starts immediately when I turn on my headlights, but can creep up on me with just the position lights on, and if so changing the electric impulses like turning lights on or off will shock the central locking into stopping a few seconds or a minute or so?! Do I need an extra resistance or relay on the headlights as the low LED resistance are making a fuzz in the air 10AS box? Headlights install - they seems to be installed correctly and everything light related work perfect. Click image to enlarge Aftermarket alarm with two wires that was connected to alarm ecu (Brown+white) Click image to enlarge Car Click image to enlarge |
28th Oct 2024 12:32pm |
