Home > Td5 > TD5 2001 10J engine None air com |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 |
Hi, I have a water leak between the engine block and the assembly that directly bolts to the engine that houses the water pump. I’ve not been able to find any part details for this housing or what I think may be a seal of some sort the goes between the engine and this large assembly. As stated this assembly houses the water pump and has an idler bolted to it for the serpentine belt and I think the power steering pump. It’s a none air con truck. Does it in fact have a seal i can get hold of between these two parts? Any help would be much appreciated. Mike
Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
25th Oct 2024 6:16pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1649 |
Are you sure the water isn’t coming out of the weep hole in the bottom for the water pump?
25th Oct 2024 7:15pm |
I’m fairly sure it’s at the back of the casting that houses the pump as it’s higher than the weep hole, but I can double check but not for a couple of days. My thinking was water will tend to go down rather than up. The red pipe directly above the casting was very crusty so I cleaned this up as it was leaking from here so I thought I had solved the problem. Is sorted the pipe out but I still have a leak in the same area. Mike
25th Oct 2024 8:02pm |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 211 |
There is a O ring that goes between the accessory block and the main engine block but if your taking it off you are probably better off changing the water pump as it's alot easier when it's off. There is also a coolant core plug behind the exhaust manifold too that can leak but that tends to burn off with the exhaust heat 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
25th Oct 2024 8:40pm |
Great info thanks. Any idea of the O ring part number? Mike
25th Oct 2024 9:57pm |
Thanks for the info NickMc Mike
26th Oct 2024 1:59am |
