Home > My Defender > SKIP'S 90110 Diary
Page 6 of 7 <1234567>
X4SKP
Hello All
Jammed Rear Wiper
We've had an unexpected consequence of swapping round (and unifying) the Tyres on my wife's 110.
The Spare Tyre has now jammed the rear wiper towards the top of its sweep... so something has to change to resolve this.
It appears that a standard Landrover Defender SVX Dual Alloy Wheel with a Continental 235 / 85 R16
fitted doesn't quite work. The Rear Wiper Arm is 'standard'... this may have been covered elsewhere on D2N but either I have to bring the Spare Wheel forward 'enough' or achieve this with a combination of both the Spare Wheel and Wheel Carrier moving further from the Rear Door... or fit a bespoke Spare Wheel Carrier.
Anyone have any thoughts / experience of this... Question
Thanks... SKIP
Post #986852 26th Mar 2023 11:00am
Have you got the large flat hex nuts fitted that allow you to limit how far back the wheel goes? The only picture I have to hand is on my swingaway carrier but they should be standard on the standard bracket:
 Darren
Post #986854 26th Mar 2023 11:11am
X4SKP
Hello LRA
Darren you have identified the issue... Thumbs Up
Both my 90 and this 110 came without these 'adjustable spacers' on the Spare Wheel 'bracket'.
I need to source a set, as a look in my workshop has revealed I haven't had these and forgotten
(which I'm taking as good thing), but as soon as I saw your photo I knew you had 'guessed' it right
thank you. SKIP
Post #986894 26th Mar 2023 4:09pm
Heh, heh, at least it's a nice easy solution Smile Darren
Post #986936 26th Mar 2023 8:05pm
X4SKP
Hello All
Easy to source the Spare Wheel Carrier Spacers at around £20 (+P&P in most cases).
But went down the DIY Route with X3 High Density Nylon Washers 55OD 16DIA Hole / 8mm Thick.
Rear Wiper / Tyre Clearance is returned... Thumbs Up
 SKIP
Post #987040 27th Mar 2023 5:10pm
X4SKP
Hello All
Couple of 'quick' jobs that got completed as a result of a pre-MOT inspection.
OME Steering Damper
An impulse purchase really last year when I was pursuing a 'faint' Steering Wobble at 55mph which ultimately was solved by a all round tyre swap and re-balancing, my guess is that after 8 years and 50K mileage on my old set of Copper Zeon's they had become un-balanced...slightly.
Looking around I spotted this... Shocked
Clearly this OME Damper had failed with Oil present on both the Damper lower end and the Steering Guard. No idea how long, or bad this is, as there were no effects noticed when driving.
Off with the OME and luckily I had held on to the original, which is 7 years old and has covered 45K
mileage. Contacted the seller for this OME Damper, provided proof of purchase (9 months old) and
a full refund was issued, together with the claim 'this is very rare in our experience'
Thought i'd paint the OEM Damper before refitting... Thumbs Up
Steering Ball Joints
Whilst generally pulling on stuff that shouldn't have any play, I noticed just the beginning of movement in the Steering Track Rod Ball Joint. I had remembered a comment from an MOT inspector previously that if a Ball Joint has a hole in the thread to accept a Split Pin, one must be fitted. My 90 has SS Nyloc Nuts on all 3 Steering Ball Joints, these Ball Joints typically have OEM Castellated Nuts and a Split Pin. My 90 came to me at 3 years old and 6K on the clock, I have never changed the Ball Joints.
I had a look at my Wifes 110 and it is 'as it should be' (Castellated Nuts and Split Pins).
So phoned Land Rover Parts at my local Dealer to be told that they now no longer supply these Ball Joints... Exclamation
Is that really true... Question So plan B was via my Independent...
One Steering Track Rod BJ / RH Tread and Two Drag Link BJ's / RH and LH Threads
Thes BJ' are similar but different to the OEM so you can't just count exposed screw threads and swap over to keep all the set up as before, so I measured... as accurately as I could before removing the Track Rod Arm and Drag Link.
Now this is where it gets 'interesting'... there is something like 40mm of Thread engaged to get loose,
No amount Penetrating Oil and encouragement would loosen things up... so I ended up putting about 5 minutes of heat into each area...
and then shocking the Thread with two hammers... this worked well Thumbs Up
All BJ's removed.
All new BJ's in place, with numerous re-measuring of set up distances...
Back in place...
One 'interesting' aspect to fitting the new BJ is that these only are supplied with Nyloc Nuts and whilst the Thread did have a hole for a Split Pin, when the Nut was Fixed Tight No hole was exposed, so it was not possible to fit a Split Pin even though it is not ideally designed to work with a standard Nut.
The Pin would have some use I guess in preventing the Nut unwinding, but hopefully the Nyloc will do its job here.
Job Done... Thumbs Up SKIP
Post #1017167 2nd Dec 2023 6:06pm
A stiff nut is just as good as a castellated nut with a split pin for this application, and you should only use a split pin if you are using a castellated nut.
There is no engineering reason why you can't use a stiff nut in place of a castellated nut on a cross-drilled pin and I am not aware of any reason why it would be an MoT failure point, from an engineering standpoint it is wholly satisfactory since the "loaded" portion of the pin is below the cross-drilling. It is highly likely that the cross-drilling will be completely obscured by the stiff nut anyway.
Post #1017189 2nd Dec 2023 8:23pm
X4SKP
Hello blackwolf
I agree, thanks for the response, these BJ’s had the cross drilled holes for a split pin approximately 6 threads down, and when fitted 3 threads were left exposed, so no visible cross drilled hole as a results. If the MOT guy was correct, then my current arrangement doesn’t ‘violate’ that (his) rule.
The previous BJ’s removed’ I’m fairly certain were the originals fitted by Land Rover, but why I had M12 Nyloc Nuts fitted I’ll never know, mechanically my 90 was standard, the changes made by BLR were essentially cosmetic.
These BJ’s from All Makes 4x4, have grease nipples on the underside, so I’ll keep them packed and see how they do, I used ‘factored’ BJ before and the joints have been let down by poor quality Rubber Gaiters. SKIP
Post #1017207 2nd Dec 2023 10:50pm
X4SKP
Hello All
Had a grand day out today, (well morning) and I thought you might like to see...
By a combination of chance and a lucky (almost) last minute ticket allocation I joined with another D2N member the CTC (Chelsea Tractor Club's) trip to Bremont, the British Watch Manufacturer based in Henley-on-Thames. We slotted into their convoy for the last 15-20 minutes drive into Henley. Approximately 100 Vehicles attended, with the star of the show being Oxford from the First & Last Overland.
Itinerary
• Saturday the 27th of April 2024.
• Meet at Belgrave Square: 8:00am
• Commence drive to Bremont: 8:30am
• Arrive at Bremont: 9:30am
• Address: The Wing, Reading Road, Henley-on-Thames, Oxon RG9 4GE
• CTC x The Last Overland talk: 11am
• Event wrap up: 12:00
So pictures tell the story best, but a few observations initially. Bremont have an impressive history of supporting / sponsoring individuals and teams who shall we say... live a little on the edge. They also have a strong aeronautical ethos which runs through many aspects of their business. Starting in 2002 making Pilots Watches they moved into their Manufacturing and Technology Centre in Henley in 2021.
If watches are your thing (or could be) their story is a great one for the UK and well worth a closer look.
Bremont Henley-on-Thames
Oxford > First Overland 1955 / Last Overland 2019
Turn Out in all forms...
Foley 6X6...
New 130 (almost the same length as the 6X6!)
V8 Fire Tender
Interesting Aeronautical design detail within Bremont
Early Martin Patent Ejector Seat
There is a very tempting selection of Watches to view
Ewan McGregor and Charlie Boorman's R1150GS Long Way Round / Down Bikes
Peter Hickman's BMW S1000RR Super Bike on which he set the Isle of Man Senior TT
average lap record time at 134.452mph
Alex Bescoby The Last Overland
Best 'Security Guards' position on campus...
Overall around 2.5K was raised for the RNLI today so Thumbs Up to the CTC SKIP
Post #1033065 27th Apr 2024 5:27pm
L110CDL
Thanks for posting Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1033740 3rd May 2024 8:25pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Nice update Thumbs Up
Reminds me I’ve the last overland book on the shelf. I’ll have to pick that one up next 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1033768 3rd May 2024 10:48pm
X4SKP
Thanks L110CDL and Rosco
During the talk from Alex Bescoby, he talked about early plans for another Land Rover Overland Trip,
this time using one of the First Range Rovers to complete the Pan American Highway (a longer journey than London to Singapore)... and do it again.
If confirmed this is going to happen no-doubt more details will emerge,(I'm speculating here) but it may be using one of the two RR supplied to the 1971-1972 expedition, where some creative mechanical work arounds were required to get through the notorious Darién Gap.
Good luck to Alex in his preparations... Thumbs Up
More from the CTC Bremont day out...
 SKIP
Post #1033869 5th May 2024 2:48pm
X4SKP
Hello All
Busy summer, so now catching up on a few Defender TODO list tasks... Shocked
110 Wheel Spacers
The 110 has standard wheels and running gear set up... it is understandably a touch less manoeuvrable than a standard 90, particularly its turning circle... we live in a rural setting with a country lane as access, to reverse into our driveway next to the house involves being fairly precise in your initial 'coming to rest' position, with the front of the vehicle close to or touching the opposite hedgerow. Despite a 12" gate it is easy to end up taking two goes to get in, not ideal with the local farm and horse livery traffic that typically arrives mid-manoeuvre.... so time to improve things.
My chosen wheel spacer is from Rakeway Motorsport
https://rakewaymotorsport.co.uk/wheel-spacers-adaptors/
Their website image was wrong at the time of ordering, we went for 30mm Concentric Spacers with All fixing Nuts to the Hub. Code No. RWSA05. You reuse your existing Nuts to secure the Wheels to the Spacers.
X4 Spacers £310-320 delivered (2024)
I know its just a box... but its worth acknowledging the Parts were Packaged well... Thumbs Up
Disassemble the linked Spacers...
Degrease / Clean the Hubs, ensuring as true a mating surface as possible, I used some Silicon / PTFE Spay between the Aluminium Spacers and Steel Hubs also, avoiding any overspray on to the brake parts (Disks / Callipers)...
Secure the Spacers to the Hubs... Torque Settings are advised to be the same as Alloy Wheels
normally between 110 N-m and 120 N-m. I was on the upper end of this, you can generally feel what
is around the right tightness before the Torque Wrench comes out...
In addition its advised to progressively tighten 'diagonally' opposite Nuts progressively down to the required point...
Locate Wheels onto Spacers, all now returning to looking 'standard'...
Just a glimpse of the Spacer in situ...
With both front wheels off the ground, adjust the Steering Stops to give the improvement of Turning Circle now available, check the Tyre clearance carefully at opposite lock, I went for around 10mm clearance at standard Tyre Pressures...
The end result is a noticeable improvement, it just turns tighter, not massively but enough to notice and take the 'will she wont she' get round when negotiating car parks, and reverse parallel parking etc.
Also (IMO) the Standard Wheels / Tyres on a Defender sit better within the wheel arches with an overall 60mm wider Tracking. Probably there is also an improvement in the side-to-side rolling of the vehicle, but this has not deliberately tested as this kind of steering (as we know) under normal conditions is to be avoided.
A Modification worth the effort and £. SKIP
Post #1049766 25th Oct 2024 3:00pm
L110CDL
Thank you for the update from your " to do " list Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1049795 25th Oct 2024 7:40pm
Procta
where did you get the spare wheel lock ? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1049816 26th Oct 2024 12:22am
