![]() | Home > My Defender > SKIP'S 90110 Diary |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello Procta
90 Spare Wheel Security This was a DIY arrangement after (at the time) failing to source anything suitable. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Mantec Swing Away Rear Wheel Carrier (Now Modified to prevent slight rattling at 30K mileage). Rakeway Spacer (shown) but now swapped to a Terrafirma Spacer. LRX Range Rover Evoque Wheels (came with Vehicle). Central Aluminium Dual Spigot (Sleeved). Stainless Steel Marine Bolts securing Spigot to Spacer Mounting Plate and Wheel Carrier. Marine Alloy Decking Mount (used to secure a Deck Table) now repurposed. 10mm White Nylon Backing Plate with 5mm Neoprene Cushion Face against Wheel. Federal Lock (anti tamper / drill). Wheel Lock Nut (for good measure). ![]() Click image to enlarge Overall this has worked well. There is also a gain in mounting the Spare Wheel now a two step process, first the 'big' lift (just get it on the Spigot) then manoeuvre and locate onto the Studs. SKIP https://www.defender2.net/forum/topic83242.html |
