Home > Maintenance & Modifications > Fuel pickup from filler neck.
keith
Is there a correct angle for this pickup to be inside the tank?
The pipe is clearly angled so how how should it be inside the tank?
Picture illustrates my position of the pipe leaving the filler neck.
Post #1049633 24th Oct 2024 12:08pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
It looks a similar position as on ours.
As long at the pick up is able to reach the fuel then it will be fine - the angle of the bend in the pick up line will feed down into the tank and scavenges fuel
You can test it by sucking on the hose to see if the fuel flows. (maybe use a syringe of syphon pump as the fuel tests awful)
Both of our defenders have the same and the heater works until the tank only has 1/4 left - it’s a good system as it wont drain the tank and leave you stranded. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #1049667 24th Oct 2024 5:04pm
keith
Thanks pal for confirming the position is correct. I’m getting a constant E-8 code on my new heater, I’m told that’s a fuel code or not getting enough fuel. The pumps working but not sure enough fuel is getting up there. I’ll keep at it.
Post #1049709 25th Oct 2024 12:10am
revd
Try running without the inline filter
You could also file the tank end of the pick up pipe at 45 degrees to be less restrictive
Post #1049714 25th Oct 2024 8:04am
wyvern
you may have picked up some crud from the tank so try blowing back into the tank to clear the tip of the pick up ... i had this happen after some off-road driving ...
couple of simple things to check -
Are you getting fuel out of the pick up feed ?
is there fuel on the heater side of the pump ?
have you ran the start up process a few times to bleed the system of air ?
its not a complicated system but just needs some persistence to get over the initial set up .
Good luck and hope it gets sorted for you soon Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #1049715 25th Oct 2024 8:38am
keith
Thanks Revd & Wyvern for positive and intelligent and intuitive advice. All points will be tried 😀
Post #1049755 25th Oct 2024 2:19pm
jst
You normally have to run them 3 or 4 times to purge air.
Assuming fuel pickup hose is correct ID. Can you hear fuel.pump ticking away?
Does it start to fire or just pump stops ticking and code appears?
The 45 angle on pipe goes down into tank so not as shown in pic orientation Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1049767 25th Oct 2024 4:07pm
landy andy
My old style controller has the ability to run the pump independently so can purge fuel. Would think they all have this option.
Post #1049771 25th Oct 2024 4:56pm
keith
Jet,
I have the pickup pipe inserted correctly 👍. The pump is working and I’ll place inside a box. I’m going to shorten the fuel line and remove the filter. What is the correct ID of fuel line? As I have replaced the green plastic with black car line.
Post #1049773 25th Oct 2024 5:18pm
revd
1.5mm id
Post #1049779 25th Oct 2024 5:52pm
jst
keith wrote:
Jet,
Tiny! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1049780 25th Oct 2024 6:08pm
