Home > Puma (Tdci) > Stuck in Reverse
Kev the Rev
United Kingdom 2007 Defender 90 Puma 2.4 HT Keswick Green
Stuck in Reverse
I recently got my Defender Puma stuck in reverse gear.
There are loads of threads on here about being stuck in first gear but nothing about being stuck in reverse
This time last week I had never heard of gearbox detents but all the threads pointed to this being the problem so I bought a full set of detents from Ashcroft
I spent most of the weekend doing the 20 minute job to remove the trim, tunnel cover and gear levers to get to the gearbox and then waited for the detents to turn up on Monday
The vertical detent to the left of the gearlever is the one that causes the problem with first gear but which one is for reverse?
It turns out that the horizontal detent right next to it is the one for reverse.
Luckily my detents were the old style mushroom type so very easy to pull out with mole grips.
The detent spring on reverse gear was very weak so maybe that's why it got stuck?
As soon as the detent was out, the car came out of reverse.
The new detents went in very easily, with a bit of threadlock, but I hope I never have to remove them as there is nothing to get hold of with the new type.
With hindsight I realised that I didn't need the full set of 5 (4 small and 1 very large) because I only used 2 of the small ones and you can buy them as single items
Just make sure that the groove on the shaft that you can see at the bottom of the opening is lined up before you insert the new detent spring.
I've driven the car backwards and forwards so just need to get all the trim back in now, a 20 minute job
Thanks to the folks who offered their advice, blackwolf, Phil at Jake Wright in Burley and particularly Dave at Ashcroft (Ashtrans) who was very patient with a newbie
Post #1049707 24th Oct 2024 10:57pm
Stacey007
Hello
Mine got stuck in first the other week as I started it outside the car while i was going to put stuff in the back. I always leave in gear and ;thought; it was out.... it wasn't and jumped forward then stuck.
Like you I undid the trim, leavers etc (carpet is the biggest pain) then on Book face someone said just hold the gear lever with both hands.... and move it clockwise then anticlockwise like your mixing syrup but quite hard.
Sure enough it 'popped; out so I put it all back together, His has been ok since doing it for 3 years... so I guess hopefully ok? if not at least I know what to do Thumbs Up
Post #1049718 25th Oct 2024 8:03am
Kev the Rev
I wasn't so lucky, the RAC man said he knew what to do but he couldn't budge it
Post #1049721 25th Oct 2024 8:44am
Re: Stuck in Reverse
Glad you got it sorted, and thanks for the useful feedback about which detent is the reverse one. Thumbs Up
The selectors in the MT82 are fairly complex and it is not easy to work out from the WSM etc exactly which selector shaft is which, so your post is especially useful and adds to the collective body of knowledge.
Post #1049738 25th Oct 2024 10:34am
Glad to hear you have managed to sort it out. Thumbs Up $W33T $0U7H3RN $UG4R
Post #1049768 25th Oct 2024 3:07pm
