Home > Maintenance & Modifications > Wing top checker plate
fatboyron
Hello everyone
So I've just taken off the checker plate off the top of the Wings again a couple of years ago I took them off and sprayed them with raptor which didn't take to the checker plate that well. So this time I'm going to sand them down so they're flat this time and then spray them again with raptor. So each side is held on by 5 nuts and bolts and every time you've got try and get your arm inside the wings to actually get to the nuts while you're undo the top which is a pain especially to try and hold the nut I'm putting them back as a nightmare as well what is everyone else been using I was thinking maybe like a rivnut into the wing top and put the checker plate on it'd be a lot easier to screw into any help or advice would be much appreciated.
Post #1049551 23rd Oct 2024 3:50pm
NickMc
You need to acid etch them for it to stick
Post #1049553 23rd Oct 2024 4:08pm
Ianh
Rivnuts will require the holes in the wingtops to be significantly larger ! You sure you want them to resemble a Swiss cheese ?
Post #1049556 23rd Oct 2024 4:20pm
As nickmc mentioned, plus some red 3m scotch pads will be useful but don’t sand too much or you’ll end up with no treads left.
Paint stripper first would be a good idea to lift most off first.. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1049557 23rd Oct 2024 4:32pm
bodstruck
Having had the misfortune of having to sand a lot of Raptor in the past, I would sell those on, buy new and then rivet them on.
Not sure on the going rate right now but surely for around £100 you can get new ones. Versus hours of effort plus £40 for a bottle of raptor.
As ever, personal choice but I'd save my effort for other jobs. Thumbs Up
Post #1049558 23rd Oct 2024 4:39pm
revd
I'm not a checker plate fan but a pal of mine removed his alloy cp and replaced it with https://uproar4x4.com/products/land-rover-...quer-plate - have to say it was an improement
Post #1049559 23rd Oct 2024 4:58pm
landy andy
OMG. That uproar stuff is vile. I can’t believe anybody would have that, let alone pay for it. Shocked Shocked Shocked
Post #1049561 23rd Oct 2024 5:06pm
You know what they say each to their own, this is why each Defender is different.
One of the biggest issues is over price, it’s amazing how many extortionate prices are out there.
(Often parts the sane quality from different places, with a doubled price mark up).
Their side steps are nice but not £1200 nice. Laughing ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1049562 23rd Oct 2024 5:21pm
revd
it is well made- have to say I think it suits his black 90 PU and not everyone is looking for the cheapest stuff
Post #1049573 23rd Oct 2024 6:50pm
landy andy
“ not everyone looking for the cheapest stuff” Rolling with laughter Rolling with laughter Rolling with laughter
Post #1049608 24th Oct 2024 6:41am
You know what they say, fools and their money are soon parted. There isn’t any need to argue, as my original point was stated, each owner has their own preferences and free to choose what they like.
As I mentioned before, it’s astonishing how you can find almost the same parts sold at different vendors for wildly different prices often for the exact same parts.
£1200 for electric side steps like some Wranglers have I can understand, and that is still a lot of money.
But not for just static side steps, considering most on the market are in the £240 to £480 price range.
Value doesn’t necessarily buy taste, there is for example the Khan range, but someone will buy it, probably lots of people, so it’s all in the eye of the beholder.
And that is quite fine by me. Mr. Green ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1049637 24th Oct 2024 11:23am
Ianh
Back to the original questions. Is there a tool you could make out of a bit of flat bar that you can use to position and hold the nuts while you do them up ? Far better than drilling big holes for rivnuts.
Re the Chequer Plate, better to get it blasted, then acid etch prime, then spray with a hard chassis paint.
Post #1049643 24th Oct 2024 12:43pm
fatboyron
Thank you everyone for your replies. I do have a pop rivet gun so I think I'll use that to put them back on like I say spraying raptor is not a problem I pretty much done everything on the truck that's black wheel arches grills roof bed the lot. For some reason it just didn't like the checker plate that's why ill just sand it down so it's flat and then spray it again the only thing I don't like is the foam on the back seems to trap water maybe some sealant around them
Post #1049648 24th Oct 2024 1:27pm
I think you are right to just use standard rivets, and avoid rivnuts, not only will that enlarge the holes as has been mentioned but they’ll seize as well if ever you wanted to remove the plates and then that’s a real problem. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1049653 24th Oct 2024 2:21pm
Smyles_
Denmark
Off Topic
I have come only to compliment the colour of your 130! Thumbs Up
What yellow is it exactly? Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #1049673 24th Oct 2024 4:37pm
