Home > My Defender > As yet unnamed 130 - Overland Build |
Joel Member Since: 18 Oct 2020 Location: Rotherham Posts: 75 |
Hi All,
I decided to bite the bullet and start a 130 overland build. I have been considering making a bit more of an overland vehicle for a while. This popped up on Fb marketplace in Buckie, Scotland, so I took a risk and after speaking to the seller - its now sat on my drive. 2004 plate TD5 that lived in Northern Ireland for most of its life. Click image to enlarge Slight shout to AIC Transport who shifted it, they were a delight to deal with and cheaper than the train fare and hotel, diesel to go and get it. She's a 130 with a big old box on the back, which I am not going to keep - I want a more overland style back so the box will be for sale at some point. The bodywork is in good shape, chassis is a little scruffy, although never been welded. Interior is very battered, but it's been a working vehicle so thats to be expected. Once I have a bit more of time to inspect the chassis I'll decide if I want to replace it now, while its easier to do, or just see if I can get it blasted and galvanised. I'm planning on putting an M57 engine in her, along with a ZF 8 speed box, my knee suffers a bit with my manual TD5 110 so I want the comfort of something a little less achy, and its going to end up being pretty heavy so the M57 should give it nice bit of extra power. My 110 DCPU will still be my main vehicle, but I want to make it a bit more of a daily. |
21st Oct 2024 5:28pm |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 881 |
Nice
I have a massive 130 itch I need to scratch so looking forward to seeing this progress. |
21st Oct 2024 7:18pm |
So the previous owner gave me a bit more info.
The truck was originally built by Landrover special vehicles (as I think a lot of 130's were) - shipped to the Republic of Ireland and used by ESB - Electricity board, it was then bought by the previous owner and moved to Northern Ireland, then when he moved to Scotland it came with him. It was a steal, including getting it to me it was less than 11k. It's been used but i like the charm it has. 110 DCPU TD5 02 130 DCPU TD5 04 |
21st Oct 2024 8:11pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7952 |
you wont regret it.
if i did mine again i would of fitted an richard m57 bespoke galv chassis and then know its something you will never need to worry about. the m57 will suit it well. look at gearing carefully and cooling. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
21st Oct 2024 8:59pm |
Thanks.
What ratio transfer box are you running? 110 DCPU TD5 02 130 DCPU TD5 04 |
21st Oct 2024 10:06pm |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 432 |
It sounds like they get hot then? The impression I’ve got is just stick it in and it will be fine, is this incorrect? |
21st Oct 2024 10:09pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1601 |
Very nice, if it came from over here likely came out of Charles hurst, Donelly Bros or T.P. Topping?
21st Oct 2024 11:30pm |
1.3 Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Oct 2024 7:04am |
Depends what your doing with it and gearing and cooling pack used. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
I have an alisport td5 rad and intercooler which I am lead to believe is enough, plus a revotec tan. 110 DCPU TD5 02
130 DCPU TD5 04 |
22nd Oct 2024 10:09am |
