![]() | Home > P400e Area (L663) > Rough Idle |
A1C6 Member Since: 15 Oct 2024 Location: Australia Posts: 58 ![]() ![]() |
How many k's has it done?
gcjt Member Since: 18 Jun 2023 Location: Gold Coast Posts: 8 ![]() ![]() |
Just passed 5k. Had a good mix of freeway and city driving.
I see. We used to own a P400 and it didn't seem to be rough. Are you sure weather it's a P300 or P400? I don't think you can get P400e anymore... only P300e.
Thanks.
In the hybrid P400e it comes with the 2litre 4 cylinder petrol rather than the 6 cylinder in the P400. Correct, I have one of the last the P400e, although I believe the P300e is same engine but detuned to output less power/emissions. I never had the chance to test drive any other P400e as they weren't available in my market prior to my order … so I don’t know how smooth the 4 cylinder petrols normally run. It’s fine at speed, just a little rough on idle and seems to hesitate and stutter when I feather it going up hill at just above idle, eg when parking on an incline. |
jimjamken Member Since: 01 Mar 2023 Location: Surrey Posts: 87 ![]() ![]() |
Hi gcjt, I also get a rough idle on my p400e (definitely the 400bhp). I've had it since May and only notice it when it's the first time idling on the ICE - almost like the timing is out! Not sure if it's just part of the normal running of the engine when it suddenly gets worked after the electric runs out.
mlambton Member Since: 20 Apr 2024 Location: Devon Posts: 22 ![]() ![]() |
I have the P400e MY24 with 3k miles. I would say I get some fluttering on idle too. I also occasionally get a surge from standstill (revs going above idle speed) when the engine is cold and in hybrid mode 2024 L663 110 Defender P400e Carpathian Grey
2015 Range Rover L405 SDV8 AB Corris grey 2010 Range Rover TDV6 HSE Narra Bronze sold 2006 Discovery 3 SE green sold Defender 90 td5 sold Defender 90 soft top sold |
Interesting, this sounds like what I have experienced. Good point… maybe the engine was still cold. Whole him had been driving a while, the engine had only started a couple mins prior as before that I was driving in EV mode until the battery ran out. I will have to try and do an idle test after the engine is well and truly heated up. |
Sounds like we are all in the same boat and this is a characteristic of the 4 cylinder! I think I’ve had the engine surge a couple times also. It’s a shock dealing with the quirks of the engine after being in EV mode for a while, EV is so smooth and refined. |
