Home > Maintenance & Modifications > Removal of rear door card... |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Peter, it is straight forward but a little bit of care is needed.
Remove big door handle. Slowly go around the outside of door card pulling it gently forward. There are about 8 plastic fir trees on the outside of door card. When the outside is free there is a plastic fitting in middle of door card. Attached to the door is a plastic U shaped fitting. Middle of door card is a plastic mushroom fitting which slides down back of the U shaped fitting. Gently lift door card up about 10 mm and it pops free. Then slide door card over door lever. HTH Brendan |
6th Dec 2011 12:25am |
A door trim removal tool (about £10 from Halfords) makes any door trim removal a doddle and stops you from pulling the retaining clips off the door trim and/or scratching paintwork. Just removed both my door ones replacing the door hinges, no more than 5 mins a piece.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Dec 2011 9:26am |
Bobble Member Since: 21 Aug 2011 Location: Hampshire Posts: 223 |
If you mean this one don't bother.
It's way too weedy to lever the securing pegs out of the door. Draper do a cracking one though, like a normal screwdrive but with a forked end to get either side of any lugs. |
6th Dec 2011 9:52am |
Yes it is that one and it worked a treat for me, fit for purpose and did exactly what I wanted it to! No I do not have any association with Halfrauds. The door card retaining rivets can be a b4ast4rd to get behind with the screwdriver type (which I also have) but the Halfrauds one whilst slim slides easily behind the card itself! Buy both!
6th Dec 2011 9:55am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
£3 off E-bay. I got one from POMs link a month ago
6th Dec 2011 11:44am |
WelshDefender Member Since: 02 Dec 2011 Location: Gwent Posts: 62 |
I use a kitchen fork. Seems to work well enough!!
6th Dec 2011 3:59pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
First remove the four torx screws securing the door close bar then, you only need to pry the corner with a tool of your own choice, I used a flat head screwdriver. You then use your fingers to carefully pull away the panel and release the other clips.
Click image to enlarge |
7th Dec 2011 10:27pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Yep, there has been more than one thread on here about how to get the Puma card off, once the bar is off it's just a question of starting at one corner and gently easing the fixings away - I've rarely used anything more than fingers for the job. Removal of the plastic insert behind the interior handle is probably the fiddliest bit. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
8th Dec 2011 12:01pm |
pjh Member Since: 22 Nov 2010 Location: West Yorkshire Posts: 126 |
Many thanks everyone really helpful - I'll have a go at the weekend.
Peter Defender 11MY USW |
8th Dec 2011 4:51pm |
