Home > Maintenance & Modifications > Removal of rear door card...
pjh
Hello All,
I need to remove the rear door card in order to install a rear window security screen.
Any tips on removal?
Kind regards,
Peter Defender 11MY USW
Post #104912 6th Dec 2011 12:13am
leeds
Peter, it is straight forward but a little bit of care is needed.
Remove big door handle.
Slowly go around the outside of door card pulling it gently forward. There are about 8 plastic fir trees on the outside of door card.
When the outside is free there is a plastic fitting in middle of door card. Attached to the door is a plastic U shaped fitting. Middle of door card is a plastic mushroom fitting which slides down back of the U shaped fitting. Gently lift door card up about 10 mm and it pops free.
Then slide door card over door lever.
HTH
Brendan
Post #104915 6th Dec 2011 12:25am
K9F
A door trim removal tool (about £10 from Halfords) makes any door trim removal a doddle and stops you from pulling the retaining clips off the door trim and/or scratching paintwork. Just removed both my door ones replacing the door hinges, no more than 5 mins a piece.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #104964 6th Dec 2011 9:26am
Bobble
If you mean this one don't bother.
It's way too weedy to lever the securing pegs out of the door.
Draper do a cracking one though, like a normal screwdrive but with a forked end to get either side of any lugs.
Post #104970 6th Dec 2011 9:52am
K9F
Yes it is that one and it worked a treat for me, fit for purpose and did exactly what I wanted it to! No I do not have any association with Halfrauds. The door card retaining rivets can be a b4ast4rd to get behind with the screwdriver type (which I also have) but the Halfrauds one whilst slim slides easily behind the card itself! Buy both!
Post #104972 6th Dec 2011 9:55am
Zagato
£3 off E-bay. I got one from POMs link a month ago Thumbs Up
Post #104988 6th Dec 2011 11:44am
WelshDefender
Wales
I use a kitchen fork. Seems to work well enough!!
Post #105059 6th Dec 2011 3:59pm
Lorryman100
First remove the four torx screws securing the door close bar then, you only need to pry the corner with a tool of your own choice, I used a flat head screwdriver. You then use your fingers to carefully pull away the panel and release the other clips.
Post #105463 7th Dec 2011 10:27pm
Happyoldgit
Yep, there has been more than one thread on here about how to get the Puma card off, once the bar is off it's just a question of starting at one corner and gently easing the fixings away - I've rarely used anything more than fingers for the job. Removal of the plastic insert behind the interior handle is probably the fiddliest bit. Steve.
http://forums.lr4x4.com
Post #105507 8th Dec 2011 12:01pm
pjh
Many thanks everyone really helpful Thumbs Up - I'll have a go at the weekend.
Post #105561 8th Dec 2011 4:51pm
