Home > Maintenance & Modifications > 110 Defender Suspension (again ???) |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4222 |
I'd speak to Gwyn Lewis and get his recommendation on the front springs. Especially as you are thinking of using Gwyn's kit anyway. You can use the Discovery spring isolators as packers to fine tune the front ride height too. 2007 110 TDCi Station Wagon XS
16th Oct 2024 1:55pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5753 |
As above talk to Gwyn. I’ve run his setup with and without roof tent, and both setups without ARBs and no issues.
Gwyn’s OME springs will give you a 20mm lift, but hardly noticeable. |
16th Oct 2024 2:57pm |
revd Member Since: 20 Apr 2024 Location: England Posts: 153 |
why not just replace all the worn stuff with new genuine LR stuff?
16th Oct 2024 2:58pm |
JereMustang Member Since: 16 Oct 2024 Location: Saône et Loire Posts: 4 |
I've asked already for a kit and recommend the medium duty springs. He doesn't do OEM springs. But the OME has a 1" difference + the stiffness which will make it a bit higher, however this will be the same with any HD regarding stiffness. I just want to avoid as much as possible any more modifications from a lift. How was the feeling with the kit on the road? Did you ever run it with stock springs ? Last edited by JereMustang on 16th Oct 2024 6:43pm. Edited 1 time in total |
16th Oct 2024 5:57pm |
I mean, nothing against it but it's going further and further away from genuine so not everything is coping with it. It's already setting lower with the additional weight compared to without, and still missing a bit. My initial plan was to get genuine LR springs and just change the shocks. |
16th Oct 2024 6:04pm |
No I never run it with standard springs, I swapped all across in one go, this time with a full set of SuperPro bushes. The vehicle is far more stable on the road than the used LR kit, and that is with me running the Challenge kit. |
16th Oct 2024 7:15pm |
Well that's the road I'm thinking of going, was just debating on springs, what kind of load are you running ?
16th Oct 2024 7:25pm |
Mine is a work vehicle, and have a bit of kit aboard, with full rack. Drives really nice with a bit of kit in it but is a bit too firm empty, which it rarely is. Would be happy to have the roof tent on if I still had it, and it works well in work mode. Would think ideal for you with full rack, and RTT
16th Oct 2024 7:47pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8113 |
My 110 was a camper, now runs part loaded sometimes with roof rack, does tow 25% of its mileage.tows 2.5 to 3.5t.
110usw 2010. I ran std springs alrond, purple brown rear with rear airbags for 50k or so from new. An air bag went, so i replaced with another airbag that did 20k miles I have now gone to genuine rear helpers inside take off purple brown rear springs and iirc yellow/white genuine front springs. Fitted this at 90kmiles or so, on 108 now and all is good. Std length travel OME medium.duty shocks alround, pin pin rear with Gwyns top mount. For me that setup works really well, off road frequently, either work and or owing. Sits pretty standard when loaded, slightly higher on back with the helpers when not towing and empty. Firm ride. My 130 is heavy, 3.3t with awning, rack, rtt on board everything and lots of batts.again standard lr springs front and rear. Purple brown again rear. Currently airbags inside springs on rear at 25psi. Increased to 35psi when towing, 10% mileage 2 to 3t, Same shocks as 110 with Gywns same top rear mounts. Arb fitted to. I don't find the articulation limit from it hindering, but then I have a rear locker too. The rear arb with rack, rtt etc is a must for me now have tried it I wouldn't go back. Airbag pressure is adjusted so it sirs normal height. Winch front and still on std front springs. There's alot to be said about sticking with genuine springs if you wish to retain std ride height. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
16th Oct 2024 8:34pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3334 |
For a non standard weighted vehicle you would be better off taking it to a specialist for corner weighting. Ride, height and weight distribution will be set up perfectly for your truck and it’s intended use. Oh and whatever you choose in the end , get it completely rebushed first. WARNING. This post may contain sarcasm. |
16th Oct 2024 9:13pm |
If I was changing shocks then I would go with Koni adjustable
17th Oct 2024 6:17am |
