Home > Puma (Tdci) > Heater trap - Have you checked yours?
Page 2 of 3 <123>
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
That panel is on the back of the heater box but is located in front of the heater matrix.
The shredded leaves may be because they have gone through the blower fan to get there where you found them, which is the lowest part of the system.
They would also need to be small pieces to fit through the grill in the intake on the wing. A snow cowl can help prevent this.
Post #1048848 16th Oct 2024 12:07pm
Zed
jim4244 wrote:
Come on guys! Someone else open up theirs so we can see what's inside!
The suspense is killing me... Rolling with laughter
Jim
Door to Narnia. WARNING.
Post #1048855 16th Oct 2024 12:44pm
landy andy wrote:
The photo.
Aha, now I understand!
That as far as I remember is a blanking plate that covers the unused air intake port on the driver's side, since the air intake duct is on the passenger side. So to that extent you are correct, it is a hole leading into the heater box, and it leads into the fresh air (i.e., unheated, and uncooled is a/c is fitted) portion of the box. Any leaves and debris which makes it past the intake on the wing, through the intake duct to the blower unit, past the fan and through the duct into the heater box, will end up in there. So it is entirely possible that leaves and crud will end up in there.
I am tempted to remove mine to see what treasures I can find!
Somewhere I have a could of spare heater units and if I can remember where I stashed them I will try to get a photo to better explain the plate.
I am more than a little impressed that you managed to find that in the footwell and managed to remove it. It is not easily accessible.
Post #1048873 16th Oct 2024 2:58pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
@blackwolf Thumbs Up
Makes sense, as the heater itself seems to be the same for RHD and LHD but obviously the ducts aren't.
https://www.lrworkshop.com/diagrams/land-r...ix_44980#5
https://www.lrworkshop.com/diagrams/land-r...ng_44977#1
"There is no name recorded for this part." - how about "locker C-18" Cool
Post #1048886 16th Oct 2024 5:16pm
Zed
blackwolf wrote:
landy andy wrote:
The photo.
High praise indeed!
If you do get a chance to have a look I’d be very interested in what you find! WARNING.
Post #1048892 16th Oct 2024 5:58pm
Zed
Has anyone had a chance to check theirs? It takes less than a minute to do and it would be interesting to know what others find. WARNING.
Post #1050144 29th Oct 2024 9:59am
macfrank
sorry was busy doing the CarPlay upgrade, plus it's a bit awkward to get to the panel; is it the three screws you can see in the picture? Is is easy to refit after removing?
Post #1050195 29th Oct 2024 2:48pm
Zed
Very easy getting it on and off. WARNING.
Post #1050206 29th Oct 2024 4:50pm
Torx bit by the looks of it, I have read before something about with service parts about a “cabin filter”.
But info on that is sketchy, so was info on the parts if any.
You certainly can hear some small amounts of debris around there if anything gets in there.
Was there any signs of any kind of filter at all or just a collection “void” that could be cleared out?
Post #1050215 29th Oct 2024 6:17pm
Possibly along these lines:
https://www.autopartspro.co.uk/carparts-on...r-defender
(Just saw the link and copied over quickly I haven’t had a look in depth).
Looking up further info;
https://www.autopartspro.co.uk/land-rover-...mpartment?
So presumably one of those is in that location.
Post #1050216 29th Oct 2024 6:20pm
There is no filter in there, it is just an empty space (or possibly not empty if a squirrel has managed to get in).
Post #1050221 29th Oct 2024 7:39pm
Looks that way, it seems that a lot of these sites are confusing the product years and as the latest Defender does have a pollen filter they seem to be showing that the 2007 to 16 Defender does too.
It’s worth taking a look to see what has collected there though for sure.
It might be full up.
Post #1050224 29th Oct 2024 8:36pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Mine is fitted with A/C and is LHD.
Opened the panel at lunch today, and took a picture :
I am sorry to say mine do not look empty, and neither is it full of leaves for what I can see in there.
Instead the space is filled with something plastic-like and whitish .... searching the workshop manual I can only conclude that what I see is the side of the A/C evaporator. Although I'm a bit surprised for it to be that color/material.
But then, those without A/C, should have a "diffuser plate" instead of the A/C evaporator, as explained here :
@Zed : did yours looked the same ? or maybe yours don't have A/C ?
/Mat
Post #1050276 30th Oct 2024 4:19pm
macfrank
Interesting, Mat! Mine's also LHD with A/C (haven't had a look yet).
Below would be the thermostat switch https://britcar.com/product.php/534197/549...er_2007_on
Post #1050279 30th Oct 2024 4:44pm
On a slightly different note in the above diagram items 2 & 3 are well worth lubing if ever you get behind the dash with some silicone grease, on mine they were completely dry.
Helps keep all the heater controls etc moving smoothly. Thumbs Up
Post #1050280 30th Oct 2024 5:17pm
Page 2 of 3 <123>
