![]() | Home > Technical > Puma rear door latch lock |
Shafski Member Since: 19 Jun 2023 Location: Chilterns Posts: 112 ![]() ![]() ![]() |
?feature=shared
Hopefully this will sort you out. I used this when I changed my on my Puma.. It can be done ![]() _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
Rescue01 Member Since: 17 Jul 2015 Location: Aberdeen Posts: 99 ![]() ![]() |
That’s weird I’ve just received my new lock as the outer handle snapped and I viewed that video two days ago
Fitted my lock today. It took a bit of jiggling and some WD40 but it’s a easy enough job.
And I bet it felt gooooooodddd!
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 575 ![]() ![]() ![]() |
Thanks for the reply. I've already watched that video but both the old and new latch do not have a pin for the lock barrel. I'm a bit stuck at the moment.
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 938 ![]() ![]() |
The vid shows the older style lock. The barrel can be changed on a puma lock, I did it on mine a few months ago. I'll try and dig out some more info but from memory the little hole is inside the latch casing on the puma rather than outside like the tdi one. It is fiddly but there is just about access. You need a fairly long pin.
My door is still of the wagon so I'll see if I can get a photo. |
I did mine on the PUMA too, it can definitely be done. Shafski
Can't get a decent photo, sorry. But this helped me do mine:
https://www.defender2.net/forum/post890567.html |
I took a good look at the new part and I can see the hole for the pin. Looks like a right PITA to get at. At least now I know what I'm aiming for. Thanks for the help. |
